Losi Junior X2 5-Link Hybrid
hugger19
Has thanked: 25 times
Been thanked: 143 times
Re: Losi Junior X2 5-Link Hybrid
Post by hugger19 »
i might be doing one also but hard to find all the 5 link parts.
LosiXXkid
Post by LosiXXkid »
hugger19 wrote:i might be doing one also but hard to find all the 5 link parts.
The suspension links and the rear shock ends were the main parts that were holding me back but at least I now know that it will be finished. There's more of this build completed than there is to do but there are still one or two items on my shopping list that I need to locate.
hugger19
Post by hugger19 »
good luck!
LosiXXkid
Post by LosiXXkid »
hugger19 wrote:good luck!
I wish you well if you decide to undertake the build! :)
hugger19
Post by hugger19 »
thanks!!!!
LosiXXkid
Post by LosiXXkid »
oldrc wrote:Looks really nice, what is the benefit of the 5 link over h-arms?
Benefit? For me it's the uniqueness of the 5-Link suspension.....there really isn't anything else out there like it.
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
This is looking great... can't believe I missed the 'nearly - there' shots on the previous page... you just can't beat shiny new parts!
Yes there is 'something' about the 5-link rear end... it looks so unique on a 2wd buggy (the Egress & Avante both have a similar rear suspension) & always causes quite a stir amongst the other racers trackside 8)
LosiXXkid
Post by LosiXXkid »
DerbyDan wrote:This is looking great... can't believe I missed the 'nearly - there' shots on the previous page... you just can't beat shiny new parts!
Thanks, Dan!
....."the Egress & Avante both have a similar rear suspension"........
I'm not a fan of Tamiya R/C these days as they never seemed to be able to get it right in terms of a competitive racing platform so I stand corrected! :oops:
LosiXXkid
Post by LosiXXkid »
Having recently acquired (and now fitted) a pair of front RPM suspension arms from Cedric (...thank you!), I'm finding that the standard Losi JRX2 spindles rub against the rear of the arms. What this translates to is that the steering will not operate from full left lock to full right lock without binding. Has anyone else noticed this? What's the solution......to use the RPM spindles? Or is there some other solution?
Thanks for any help offered.
hugger19
Post by hugger19 »
will be posting mine up soon waiting on 2 parts :D
LosiXXkid
Post by LosiXXkid »
Since I've been building a Junior 2/ JRx2 hybrid with the aim of running it (one day........maybe.........at some point.........), the question of rear wheel off-set/ tyre clearance has been on my mind so I thought I'd try something out.
After a bit of research, the Losi A-3031 Offset Rear Axle GENII which is used on the XXX-BK2 looked to be just right for the job. The following photo's help illustrate the improvement over the standard axle.
As you can see, the A-3031 axle is on the left with the standard axle on the right. I fitted the small Losi 'A' shock spacer to move the suspension links inwards away from the tyres on both sides.
Rear overhead view.
Losi Update 021c.jpg (126.02 KiB) Viewed 2124 times
Rear overhead view.
Rear overhead view.
Here's a close up using the standard axle...
Standard axle (A-3015)
Losi Update 020c.jpg (126.39 KiB) Viewed 2123 times
...but there's still not much in the way of clearance. Now here's the off-set axle...
Off-set axle (A-3031)
Losi Update 019c.jpg (124.17 KiB) Viewed 2123 times
...and as you can see the difference is obvious.
So now there's plenty of room for those tyres without the problem of them rubbing against the lower shock mounts. :D
Losi 'A' shock spacers.
Losi Update 023c.jpg (120.94 KiB) Viewed 2122 times
LosiXXkid
Post by LosiXXkid »
Here's the standard axle minus the wheel...
Standard axle without wheel.
Losi Update 053c.jpg (96.55 KiB) Viewed 2123 times
And here's the off-set axle without the wheel...
Off-set axle without wheel.
Losi Update 054c.jpg (95.38 KiB) Viewed 2123 times
Note the XXX-BK2 Axle spacer (A-9942) that is required.
Now, because of the greater off-set (which is about 3mm) a low profile aluminium nut is required...
Low profile aluminium nut (A-6304)
Losi Update 065c.jpg (104.11 KiB) Viewed 2123 times
Problem solved! :mrgreen:
LosiXXkid
Post by LosiXXkid »
This build has now turned into this build.....
http://www.rc10talk.com/viewtopic.php?f=27&t=41577
Return to “Losi Forum”
