I sure hope so.gomachv wrote:The stealth is due for rerelease anyway so the "shortage" should be short lived.
Just sayin
3D printed Stealth gearbox housing.
Re: 3D printed Stealth gearbox housing.
Javier -
If you look at the Traxxas Magnum 2,72
The idler is pushed up and the diff is raised
Didn't the TRX-1 use the same size diff gear as the 2,25 stealth ?
I'll have to go dig my TRX-1 out of hiding to compare
Morten Max
- teman
- Been thanked: 6 times
Hang tight, 60 bux is outrageous for a case! Also, we haven't heard back from Dynotech about the 2.6 cases yet
-Kevin
- THE H.P FREAK
- THE H.P FREAK
- THE H.P FREAK
PLEASE can I have one of those nice shiny white ones ?
Morten Max
I have an almost white one with blueish permanent marker on
Would peroxide or is it hydrogen peroxide get it all white ?
Morten Max
- Has thanked: 100 times
- Been thanked: 205 times
Hydrogen peroxide will not remove the marker, you need to use some form of solvent to remove that. The peroxide just whitens the nylon that has yellowed due to time.
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- THE H.P FREAK
HI!... Make sure to use a ultraviolet light with the Hydrogen peroxide or it basically does nothing IMO.
What solvent will remove marker and leave the nylon unharmed ??
Morten Max
- 1578 Views
Last post by RC10th
- 1484 Views
Last post by Rizzo
- 2030 Views
Last post by dinglem
- 1522 Views
Last post by jeepy2013
- 1801 Views
Last post by drbelleville
- 870 Views
Last post by Lonestar
- 54 Replies
- 8191 Views
Last post by Dcast
- 4974 Views
Last post by Carknowledge101
Users browsing this forum: Dustydrone,
timjz,
XLR8 and 7 guests
