In the past i was using nicad AA batteries and you have to put the batteries in that tray thing. When i was testing it i was using Nimh AA'sworks92 wrote:Sorry, i never get any troubles with my KO's.
If the batteries positions and connections are good..., you got to go deeper and disassemble it
Did you use Nimh pack in the past ?
Ko Ex1 addiction
- retrorobot
Re: Ko Ex1 addiction
- retrorobot
I think the on off switch works? I think because i tested it with multimeter with the on/off switch turn on and the batteries in the Radio this is what i got. Let me know what you think?DennisM wrote:Next to check is the sliding on/off switch. Disassemble the transmitter and give the on/off switch a good blast of Lectra clean or another sprayable alcohol, while operating it. WITHOUT batteries attached.
When the alcohol has vaporized You can apply the batteries and give it a try.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Before You proceed, take 8 new non-rechargeable batteries, this will give a good 12 volt supply which the transmitter was designed for. - what about the bridge between the two pcb´s. The charging socket might have a circuit that cuts the battery supply for the circuit board, could this be faulty? Dismantle all the PCB´s and check for corrosion and obvious faulty components.
Gone fishing
- tamiya
- Been thanked: 9 times
KOs that I've disassembled in the past usually have a separate internal jack for a wired rechargeable pack
to which the rear charge jack goes.
It won't have connection to the spring contacts for the 8xAA cradle;
not sure if there's diodes to drop the Vs from 8xAAs vs the wired input.
- Been thanked: 16 times
This one?works92 wrote:it's a Turnigy 2.65 1C 3S , buy on the HK webshop.
http://www.hobbyking.com/hobbyking/store/__16529__Turnigy_2650mAh_3S_1C_LLF_Tx_Pack_Futaba_JR_.html
- works92
- Has thanked: 85 times
- Been thanked: 32 times
yes.mamadoesn`tletme wrote:This one?works92 wrote:it's a Turnigy 2.65 1C 3S , buy on the HK webshop.
Thanks!
Do you mind taking a picture of how you plug the battery connector to the radio?
- works92
Here it is,
hope it could help you, sorry for the bad quality:
if you worried about flashing the Tx by pluging the battery the wrong way, don't.
it will only doesn't work.
thank's to Ko for the neutral wire in the middle.
Ok, I just connected the battery to the radio. I didn`t noticed that in the manual it says which pin is the positive and which one is the negative.
Can I leave the lipo connected to the radio when store at home at no using it?
- 24 Replies
- 17754 Views
Last post by madweazl
- 575 Views
Last post by Halgar
- 778 Views
Last post by XLR8
- 1408 Views
Last post by XLR8
- 20 Replies
- 2162 Views
Last post by Lowgear
- 2212 Views
Last post by Bmw1tech
- 1485 Views
Last post by marlo
- 1392 Views
Last post by slow_jun
