What to do with bearings that don't quite fit?
Re: What to do with bearings that don't quite fit?
Thanks for the tips, guys. Some observations:
-Tried shrink-tube, but the only one I had that was big enough to fit the bearing O.D. was perhaps a bit too thick, and when I'd try to insert the shrink-tubed bearing, it just pushed off the tube.
-Slightly better results had with electrical tape, but a similar problem happened when pressing the bearing inside the housing; some of the tape would push off and the final result, though it more or less worked, was rather messy-looking.
I'll try the tin can idea, that sounds promising and wouldn't cause the problems that the tape/tube did. I think I'm trying to get a 9mm bearing inside a 3/8" hole--just over 9.5mm--so there's not a lot of space to make up for. Might be able to try that out tonight. Last night for some reason I got obsessed with sorting & organizing parts, picking out all the flat-head and 2.6mm screws from a bin filled with random nuts 'n' bolts, because it seems whenever I need either of those, I can never find one quickly enough. :lol:
justinspeed79
Post by justinspeed79 »
Whatever you do don't try the aluminum foil, after all its cheap, easy, works great, and you probably already have a lifetime supply in your kitchen. :roll: :P
Users browsing this forum: No User AvatarAhrefs [Bot], User avatarjuicedcoupe and 5 guests
