Better Late (Edinger) Than Never...
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Better Late (Edinger) Than Never...
The 3 pin battery and 2 pin motor "amps" connectors were common on associated stuff. Later they gave you a tamiya adapter with the kit to simplify. Depending on how the 3 pin was wired you could run a 6 or 7 cell with a BEC receiver. On the 1/12 it switched between 4 and 6 cell
I have a manual. I don't have a way to scan it but I can take photos if you need specific info.Diggley wrote:So far it seems mostly complete; less a body/wing, battery straps, one counter sunk screw (for the antenna base) and a set of manuals.![]()
I found a mint battery strap in my collection & I'm sure I have a matching screw around here somewhere. I may check the scan section and possibly print a copy of the assembly manual.
"It is not how you finish but how you qualify unless you qualify bad then it is how you finish."
Words of wisdom from the Cox bros at my local track.
The manual is still available online as well, it's just hidden under a different link on the associated website.
- slotcarrod
- Been thanked: 45 times
This is the Cadillac manual but it is almost exactly the same! http://www.teamassociated.com/pdf/cars_and_trucks/RC10/Team/rc10_manual.pdf
You can find a link to all RC10 manuals in the 25 Year thread!
Rod Littau
- Diggley
Thanks for the (links) help guys.
I'd like to try to find a an old period-correct copy to keep on hand.
I still need to set up the FT sway bar.
Did these things ever come with a rear sway bar?
Projects and shelfers:
- slotcarrod
Never came with a rear sway bar!
Rod Littau
- Diggley
slotcarrod wrote:Never came with a rear sway bar!
I didn't think so.
I'd seen one equipped wih a rear set up on eBay that must have been a custom.
I remember what a big deal the F&R sway bars were on the Kyosho Turbo Ultima, but didn't recall a rear sway bar on the RC10 around that period.
I was suprised to find out I had to fab my own on the '10.
I figured a manual might have a template to help set up the correct bends.
- Diggley
Question:
What is the correct factory body for the late Edingers?
There are 2 styles still produced, but I'm not sure which matches the box.
Also, I see that the illustration shows 4 driving lights vs. the two I've seen on many parts trees..Am I missing something?
I'm debating if I want to leave it clear for display, or go for it and match the box illustration..
This will be the 1st RC car (of any make) I've ever owned that will be as close to factory stock as possible, I'd like to make sure it's accurate to the time period.
- Has thanked: 36 times
- Been thanked: 1318 times
Don't do it up like the boxart. That's been done to death.
The correct body is the protech. You can grab a new one pretty much anywhere, but new ones differ from the original. The window nets are different. You need one with the wavy netting. Some of the early reissues had it but that didn't last long.
- Diggley
scr8p wrote:Don't do it up like the boxart. That's been done to death.
Thanks for the tip!
You're right.
I've seen a bunch done that way..kinda as common as blue & white paint jobs on Sand Scorchers...
I guess I'll figure something out, I just want this one to stay painfully stock as possible.
It's funny, I've been into this sort of thing since the mid-eighties, but this one makes me feel like a noob all over again..
- Diggley
GJW wrote:thats a very nice find. looks special indeed! good price?
I tried to negotiate a better price, but considering how long I've been looking for one in this (new) condition, and how difficult it is to find an Edinger that doesn't cost a small fortune, I feel it was fair.
I paid a little over what retail would have been in the mid eighties.
- Has thanked: 7 times
Very nice buggy! I'm looking forward to watching this one progress.
Steve
Steve
- Diggley
Questions for the RC10 guru's:
I've got a white (covered) manual, it doesn't appear to be a copy. Is it correct for the mid-production Edingers?
I've only seen the yellow covers up to this point.
Also, When was the last year for the driver figure?
it's the correct manual.
pretty sure the driver came in every rc10 kit. not sure about the worlds car though.
- 1241 Views
Last post by LurkingCAT
- 20 Replies
- 2473 Views
Last post by REMJ666
- 36 Replies
- 3534 Views
Last post by THEYTOOKMYTHUMB
- 1211 Views
Last post by yellowdatsun
- 691 Views
Last post by CamplinP
- 664 Views
Last post by jaro
- 955 Views
Last post by josh
