2012 VONATS Build Help lol :)
General info, Q&A.
nvxwax
Re: 2012 VONATS Build Help lol :)
Post by nvxwax »
Thanks, I wish i could paint like that lol, I got the car and body from flipwils11, The body was painted by a guy on RCTECH that goes by W.E.D.Jim
nvxwax
Post by nvxwax »
I are there any pros or cons to the two setups below
B4 CVD's with 10GT Hubs...
B44 CVD's with Losi, RPM or CW hubs...
Using B4 rear wheels and Klein arms with each, is there a track width difference?
no difference in track width, but i think the b4 cvd's are too long. b44 rears are the way to go imo.
nvxwax
Post by nvxwax »
scr8p wrote:no difference in track width, but i think the b4 cvd's are too long. b44 rears are the way to go imo.
Thanks, I think im going to go with the B44 setup,
nvxwax
Post by nvxwax »
Ok, I have most everything on order, Here is my list for now, Im trying to keep all the white fiberglass on this build, Im still looking for turnbucles that are not hard to find but good
Chassis
Used 6302 Chassis (Black)
7305 Truck nose plate (Black)
7315 Nose brace tubes (Black)
Battery Brace Worlds Car Fiberglass
Team car Trans Brace style in fiberglass (need to make this)
Front
2701 Dynotech front suspension arms
7207 Front Bulkhead (White)
RC10T White Tower
9580 B4 Caster block 25 degree
9577 B4 Steering Blocks Inline
7222 Front Wide Axles
RC10 B4 White 2.2" Front Buggy Wheels
RC10T Team Shocks (Stock)
Rear
2700 Dynotech rear suspension arms
Used Rear Bulkhead (White)
RC10T White Tower
9756 Rear B44 MIP CVD
9608B B4 wheel spacers
7368 axle shims
70272 RPM RC10GT rear carriers
Custom Works Rear Wheel Spacer .125" (2) CSW7208
RC10 B4/B44 White 2.2 Rear Buggy Wheels
Trans
2.25 Stealth (White)
B4.1 Transmission Slipper Clutch -B4
soniccj5
Post by soniccj5 »
Here is another post that might help with your build.
http://www.rc10talk.com/viewtopic.php?f=35&t=12739&hilit=stable
ED
kaiser
Post by kaiser »
don't forget modern wheels and tires, those on the red car look cool but won't do squat on a hardpack track like the vonats. you'll also need b44 rear cvd's if you intend to use klein arms in the rear.
you'll also want limiters inside the shocks otherwise they'll extend to far.
Has thanked: 356 times
Been thanked: 470 times
Keep in mind, that the B4 caster blocks caster number is based off a 25 deg kickup- so using 25's on a RC10 yields 30 deg caster--
nvxwax
Post by nvxwax »
Charlie don't surf wrote:Keep in mind, that the B4 caster blocks caster number is based off a 25 deg kickup- so using 25's on a RC10 yields 30 deg caster--
That went over my head lol, Is there another caster block number i should be using? I got the part number from other builds i see in the Old/New thread.
Add 5 deg of actual caster to the b4 number when running on an RC10, 30 is a bit much unless you have super high traction, or really soft soil.
soniccj5
Post by soniccj5 »
I went with a b4 30 degree, handles ok, but going to try a 20-25 soon.
I personally use the 20 deg b4 blocks most of the time, the more caster you add the faster the inital turn in is, but the car is very tight off of the corners. On a very high speed track ( not RCHR ) more is generally better-but there are lots of variables
