pick my next build for me lol
discgolfer72
Has thanked: 21 times
Been thanked: 36 times
Post by discgolfer72 »
i have one space left on my car shelf
i have bags and bags of rc10 parts (no white parts left ,excpt rear and front bulkheads)
what should i build
i have 3 pans left ,and 2 trans . a stealth and a 6 gear
out of the three chassis im only intrested in 2 the 3rd is stilla wip
first i have a a stamp original black chassis with stealth and 6 gear holes i refinished it in stuff used to reinforce old car frames (tougher than bed liner and not as heavy texture)
then i have a runner quality gold pan a stamp with only 6 gear holes
im a blank slate right now excpt this will be a runner not a shelf queen
and im def going to use the 3/16 axles and andys/rpm front and rear a-arms
marlo
Has thanked: 18 times
Been thanked: 22 times
Re: pick my next build for me lol
Post by marlo »
That pan on the right looks like it was sand blasted.
discgolfer72
yup need to get some more medium for my blaster to finish it up
it was a old mid engine conversion i had done years ago the tranny shot craps so it got tore down and parts thrown in my parts bin
marlo
Post by marlo »
Careful blasting, I did one years ago and warped it. I flipped it over and lightly blasted the other side to true it up again. And the pressure was low.
teman
Been thanked: 6 times
Post by teman »
I vote for a stealth car, black chassis with wide front arms or RPM arms all around :mrgreen:
-Kevin
8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
I think you should build a Kyosho.
discgolfer72
been there done that koysho bla
lol i have a old koysho indy car that i built and never installed elect on
i was leaning tward the black chassis with the stealth but after a trip to the lhs today im still unable to end up with a complete slipper
i have the inner slipper part but thats it
i picked up a outer slipper today and some rings before that but they dont work to well with the original inner part
(found a older hobby store about 30 min from me so im gonna try there tom for more old stock parts)
any ideas
on the slipper
either look for the "correct" outer hub and clutch disc on ebay (since it's all discontiued), buy available slipper parts from a b2/b3/t3, or change the entire topshaft and use all b4 stuff.
discgolfer72
well im guessing the outer hub i bought at the lhs is a b4(rings are probably b4 as well)
and they had a b4 top shaft as well
is it a drop in replacement or do i need other parts to make it work with the old stealth trans
I don't think there's an "outer" hub with the b4 slipper. They're both the same. Whats the part number on it?
discgolfer72
#9604 was the hub i bought
nip tranny parts i have on hand
#6587 torque control spring
#7664 X2 (think these are the gt diff gears)
#7667 diff out drive (have left to )
#6614 idle gears(i know what they are for lol )
#6610 idle gear pivot (same as above lol)
#7666 drive rings
#6580
#25043
Has thanked: 3699 times
Been thanked: 1980 times
That half blasted chassis looks pretty cool. You could do some cool things with that effect if you think it through properly. 8)
discgolfer72 wrote:#9604 was the hub i bought
well you'd need another one of those, the slipper pads, spur, spring, nut, and topshaft.
all this plus the b4 topshaft.
http://www.ebay.com/itm/Team-Associated-RC10-B4-1-Buggy-Spur-Gear-Slipper-Clutch-/130875186753?pt=US_Radio_Control_Control_Line&hash=item1e78c4de41
discgolfer72
oh yea think its time i dusted this baby off and use it for this build
been trying to find a use for this old thing to maybe now is the time since om using the oval motor
discgolfer72
still can figure out how to make an edit of my post
thanks i just bought that kit you linked to ill pick up the top shaft at my lhs in the am
dug thrue my parts and pulled almost a full set of white parts
looks like i missing i front axle carrier and bolth rears
im going to use rpm arms so im good there
Users browsing this forum: No User AvatarAmazon [Bot] and 2 guests
