Need Help rebuilding Gold Pan
- RC104ever
Re: Need Help rebuilding Gold Pan
You'll also need a stealth tranny brace.
- Chris
Lots of cars...so many cars
- Has thanked: 36 times
- Been thanked: 1318 times
a square section of the trans case is raised so there's clearance for the diff gear. because of that, a square opening in the chassis is required for it to sit in.Noroc wrote:Just curious, what is the hole for? Does part of the trans hang out? If so, what keeps it from getting torn up when the car bottoms out?
There is another option before hacking up your chassis you can just keep getting the new idler gears for the original 6 gear for like $5 on ebay, after a while you will be good at replacing them. I replaced them a lot as a kid, a friend of mine swore his lasted longer by using vaseline in his gear box... Get two sets then everytime you blow a set order another.
I am currently on a limited budget. I looked into that, but decided it would just get too expensive considering how fast the trans stripped out.
- soniccj5
Along with the hole, I needed to notch a section in the rear bulkhead to fit the b3 transmission in mine.
You will also need to find a way to add a transmission brace.
Good luck.
Good luck.
Got everything mounted and working. Had it clocked by a baseball radar gun. Average speed was 68mph. May not be the prettiest, but it sure is fast!
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Just curious. What battery, rear tires and gearing?Noroc wrote:Got everything mounted and working. Had it clocked by a baseball radar gun. Average speed was 68mph. May not be the prettiest, but it sure is fast!
- RC104ever
Wow, you are doing 68 mph with a 3500kv motor?? I just installed the stealth in my gold tub, wondering how it will affect the performance. What battery are you running?Noroc wrote:Got everything mounted and working. Had it clocked by a baseball radar gun. Average speed was 68mph. May not be the prettiest, but it sure is fast!
- Chris
My mistake, it went 58. I'm not sure the battery. It was a lipo I borrowed from a friend. I was running 31 on the pinion. Not too sure on the spur.
- 2666 Views
Last post by Spoon
- 747 Views
Last post by aakoskin
- 1277 Views
Last post by DarthRacer
- 31 Replies
- 5167 Views
Last post by Sixtysixdeuce
- 1090 Views
Last post by RedScampi
- 1445 Views
Last post by Marty
- 608 Views
Last post by JPAE07
- 21 Replies
- 2330 Views
Last post by vwjuice
