Slowly getting together the parts I have and quickly discovering the parts that I dont have. I will shortly be posting a want add. hopefully I can find the stuff.
Definatly 1 of the hardest cars I have ever researched.
You have the wrong diff pulleys, however you may have aligned the chassis for these to fit but can't tell. You have 33t YZ10 95 pulleys while you should have 35t (i think) pulleys for the 870c, works 91-93, you can see one in the image below. **There is nothing wrong with your layshaft setup except that the larger bearing should have the lip on the outside.slapshot1979 wrote:
I have the correct belts, diff pulleys, but the 3 main spur gears with one ways wont fit the shaft. Will this combonation even work??
maybe a dumb question but if I install a 1 way main spur that would eliminate brakes no??
You sure do, but there is nothing wrong with the spur gear adaptor as long as the belts sits tight. Only problem is the gap, which you could plug with a washer - BUT the big issue there is the belt may tend to drift to the gap and fall off or get jammed which will not be good! I would just flip that large bearing on the layshaft to take up the gap. Let me know if the bearing flip works, if not I can get some pictures of the correct layshaft for a works 91 and 93 if you like, if yours is incorrect then all you have to do is get the right one. That way you don't have to mess about with new pulleys and belts.slapshot1979 wrote:Wow , seems I have a huge colaboration of parts of which none go together!!
LOL. not sure where to go from here. I wanted to run the corse pitch belt because I had heard they are less problems but as I find out more, all I seem to have are the belts, and the robinson spur which wont work with what I have for a layshaft. hmmm.
victor_cathedral wrote:lol all this post tells me is,... that i shouldn't attempt to resurrect one of these cars lol ! i have enough headaches with my simple rc10'sgoodluck to you though, these cars are awesome, just too much of a handful for me right now
