? about model #7035 team truck
scout guy
Re: ? about model #7035 team truck
Post by scout guy »
Yes !!! its the finally Monday truck should be here. And my wonderful girlfriend is going to bring it up to me at the psychical rehab center where I've been last 2 1/2 months will post pic's later to night. and working on a deal for another or maybe two more RC10T's can see I'm going to need a bigger r/c room .
B4-T4-SC10-RC8-B44-Slash 4x4-Baja 5b-SCX10-SCX10 Honcho-RC10t
scout guy
Post by scout guy »
couple pic's haven't started yet way to tried last night therapist worked me hard. will start working on tonight
RC10T 001.JPG (38.48 KiB) Viewed 852 times
SteveK
Post by SteveK »
Cool! That's the original box, they just changed the sticker on the side. Get some pics as you go along.
Good luck with the rehab :)
1of1547
Post by 1of1547 »
Just wanted to see how your rehab and build are coming?
RC10T Team Truck
Tamiya Clod Buster
The two I always wanted when I was a kid!!!
Sir
Post by Sir »
SteveK wrote:The HPI wheels came with a full set of adapters, which you can get here:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000106227&I=LXN057&P=K
Top left is the 3/16" adapter, bottom left is the 1/4" adapter. The other two are for regular 12mm hex wheels and then Tamiya Blackfoot-style wheels. You can use the adapters in any wheel with a 12mm hex if you trim the lip off the outer edge.
The front wheels came with these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000106227&I=LXN055&P=K
The wheels fit 11mm OD bearings standard, so one set of those adapters are to let 3/8" bearings to fit inside.
The front wheels on the Losi LXT and RC10T were the same, but Losi made some rear wheels to fit the 1/4" RC10T axle. The rear wheels for Losi trucks will fit Associated trucks with 3/16" axles.
Is the offset the same as the stock wheels and tires?
SteveK
Post by SteveK »
The rears are pretty close to the same, but I believe the fronts were about wide, maybe 3/8" on each side.
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarBing [Bot] and 4 guests
