RC 10 Model A truck conversion
creekrunner
Post by creekrunner »
RC10 Model A .......looking for the Stealth mounting template (p/n 6590) or the pattern) to upgrade the transmission...also a recommendation for brushless conversion..motor and esc . Will be running 2s 4000mah li-po. Also the pinion size for a 48 T spur. This old model A has been in a box for 30 years....Thanks !
Has thanked: 269 times
Been thanked: 2094 times
Re: RC 10 Model A truck conversion
If your pan is nice/unmolested, I might would reconsider drilling holes in it. There are plenty of sacrificial tubs on ebay.
I've always just used a spare Stealth pan as a template. But if anyone has or can make a template, I'd say that Jeff/GoMachV is the person to try.
But I wouldn't say that a Stealth is really any stronger than a properly built 6 gear (with black idle gears). With a few mods, I might would lean towards the six gear being stronger.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
if you have another stealth buggy chassis you can use that chassis as a template if you bolt them together also but yeah, if you don't this was kinda useless :P
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarBing [Bot], No User AvatarTbot [Bot] and 4 guests
