Gomachv's 4wd RC10 project- finished!
- knixdad
- Been thanked: 4 times
Re: Gomachv's 4wd RC10 project, still unnamed and unproven
Couldn't be any worse than XX4 beltsgomachv wrote:Changing belts at the track would not be fun haha! Let's just say the motor plate needs to come off. Not that hard, well...now that I've done it 17 times lol
When you releasing a kit? I'm in if you do.
- Has thanked: 1129 times
- Been thanked: 3919 times
The beauty of this conversion is how few custom parts are used. A custom noseplate, bumper, tubes, towers, pulleys and belt are the only special parts. The rest is sourcing a spare trans, kyosho steering and bones, and some dremel work.pumpkinfish wrote:When you releasing a kit? I'm in if you do.
It's still a ways off....but don't worry I'm sure I will be able to sell a few before long
I played around with the front tower today, as I wasn't a fan of the look it had going. This mimics the A&L style tower or worlds tower a little closer. Opinions?
I like it fine,gives it that 4x4 buggy look.And without the reguler buggy nose sticking out i bet it hit the jumps like no ones business.
don
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Nice.
It is more classic than the first one. I dig it.
One thing you might consider is taking the middle part of the tower (and spacer piece if that's what I see) down a bit to be perfectly flush with and minic the shape of the tranny base. I'd think the body lexan won't be out there to cover that, and if it was smooth, it'd give a cleaner look I think.
And you might be in need a new countersink bit?
I like mine to have a lot of flutes and be chinese so they get dull and easy to control real quickly... http://www.harborfreight.com/1-2-half-inch-six-flute-countersink-93342.html
- THE H.P FREAK
HI!... Looks good. Perhaps you could lighten up the front shock mount a bit with some holes? It looks very robust and solid.
Its only FWD wheel drive til you put the rear axles in!!!!
don
I tried cutting it down and adding a hole lol, this is still just a mockup tower so just trying some things outY'ernat Al wrote: One thing you might consider is taking the middle part of the tower (and spacer piece if that's what I see) down a bit to be perfectly flush with and minic the shape of the tranny base. I'd think the body lexan won't be out there to cover that, and if it was smooth, it'd give a cleaner look I think.
I may have been sleeping
when talents was being given from up above.... .....
waiting for the shakedown vid...
― Confucius
― Confucius
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
How about a half circle with the flat portion at the top.
So the smiley face the hole makes with the two center screws looks more like this
than like this
- myfordcnc
I'm starting to understand why you chose to o the way you did on this build. It's a hell of a thing trying to squeeze all that functionality in to such a small space.
Looking good.
By the way that top picture with the whole looks like a mouth with two googly eyes.
Looking good.
X2 I NOTICED THAT ALSO.ITS thinking look out here i come!!!! getoutha way!!!!myfordcnc wrote:I'm starting to understand why you chose to o the way you did on this build. It's a hell of a thing trying to squeeze all that functionality in to such a small space.
Looking good.
- 37 Replies
- 5569 Views
Last post by minimini
- 33 Replies
- 6164 Views
Last post by Dcast
- 2508 Views
Last post by fredswain
- 19 Replies
- 2948 Views
Last post by Kaiser Q
- 595 Replies
- 83465 Views
Last post by Lou0151
- 21 Replies
- 5918 Views
Last post by amx73
- 25 Replies
- 1920 Views
Last post by Frankentruck
