A-Main Bullet Fwd 4ws RC10 conversion Tribute build
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
Re: A-Main Bullet Fwd 4ws RC10 conversion Tribute build
With the new pivot arms does the left side clear the transmission case? It looks as though it would when you try to turn to the right. I see you have the wheels turned to the left in the middle picture. Maybe it is just an illusion...
Jeff
- Has thanked: 1080 times
- Been thanked: 3731 times
The only thing that doesn't clear is the left arm on the back side- it hits the battery mount standoff. With a thinner standoff or a notch in the arm it would be fine. That's what I did on the mock up arms.
- klavy69
- Moderator
- Has thanked: 628 times
- Been thanked: 294 times
moved...bumped...now wheres the updates
Patience!
I am told there may be an update very soon
Thanks for moving it Todd
Well I dropped the chassis off with sayre16 to get bent, should have it back soon. Guessing at the 10 and 15 degree angles to start with, we will see how it looks. Composite Craft wants "at least" $350 to make a mold for this chassis so I may end up doing it on my own, messing up some expensive carbon and buying tools that I won't ever use again, THEN having them do it correctly.
I know myself so well
And yes, the lines are scribed- just highlighted in black to make it obvious
- Phin
- Has thanked: 82 times
- Been thanked: 232 times
The price from CC is for completely molding, cutting, and drilling the chassis? If so, what about pricing just a blank sheet with the necessary bends and cutting it yourself?
No, that was just to make the form to build the chassis on. Material and CNC work would all be extra as well
I stopped by RC Plus today with the bullet and talked to Ron. I knew it was going to be fun when he said "oh, look a Bullet. Those things were a pile of $&%@!" Lol.
He remembered them but said they were being developed for a while (couple years!) before they made the kit in late '87. He said they were a pile of poo to drive and since they ran a different line than the rwd cars they would cross paths twice on every corner- and the fwd would win the rubbing contest. He said that car destroyed racing until it was outlawed- not that it was fast or even good, it just was in the way- and fast enough to be trouble. He said they were constantly messing with the steering. It didn't steer tight, you turned in early and let it swing wide coming out.
He also said to get in touch with Kelly (Lundsford) and that he probably still has his
we will see!
If not he gave me another contact that may have info.
It was a good day. Finally someone that remembers this thing!
- Seabass
- Business Member
- Been thanked: 12 times
I tell you what guys, if you guys have CC build the mold then provide the material to me, I will machine the chassis for both you (Gomachv) and Phin for nothing. All you would need to do is get the material to me. I will be back in the states 1 Oct and should have my shop setup and running again in Nov.
Jake
Jake
- longboardnj
gomachv this is one of my fav builds ever .. you should do another chassis that has the A-Main Bullet Fwd front end and the stock rc10 rear end. i always had a dream of a 4wd dual motor/trans kit..
That's awesome of you, Jake! I am not sure if we will go the CC route but its great to have that option! I have a few things that I need to get with you on!Seabass wrote:I tell you what guys, if you guys have CC build the mold then provide the material to me, I will machine the chassis for both you (Gomachv) and Phin for nothing. All you would need to do is get the material to me. I will be back in the states 1 Oct and should have my shop setup and running again in Nov.
Jake
Dang- that was going to be a surpriselongboardnj wrote:gomachv this is one of my fav builds ever .. you should do another chassis that has the A-Main Bullet Fwd front end and the stock rc10 rear end. i always had a dream of a 4wd dual motor/trans kit..
Phin and I both have plans for this basic platform once the "original" is finished. My plans are to end up with a stock one, a version built the way "I" think it should have been (still period correct) and a dual motor version using two front end modules. I had a maxxum front/ultima rear monster truck BITD as well as multiple Tamiya based dual motor TA01/02/FF based cars and it was hella fun!
Phin's will be a different idea but I won't give it away, ill let him do that.
- 1300GT
- Has thanked: 474 times
- Been thanked: 403 times
This is a great build Sir. Will "your" version have the motor mounted ahead of the front axle?
Chris.
Toys.............they are!
1300GT wrote:This is a great build Sir. Will "your" version have the motor mounted ahead of the front axle?
Mine will keep the general layout the same, just fixing the bump steer, steering, geometry etc to my liking
- 1300GT
Ok. I look forward to seeing it.gomachv wrote:1300GT wrote:This is a great build Sir. Will "your" version have the motor mounted ahead of the front axle?
Chris.
- longboardnj
Phin's will be a different idea but I won't give it away, ill let him do that.[/quote]
very happy to hear that .. im glad someone with your skills is doing stuff like this,i dont have the patience, time,$$ ,or tools to do the nice work your doing(im more of a rat rod kind of builder anyway)..
as far as tamiya stuff did you ever think of a ta03 dual motor car?(is that the same as TA01/02/FF based cars? )
i had a ta03, thought about dual motors when i saw it in rc car action. turned out to be too much cash and time for me to put in for a old beat up car.
- 1941 Views
Last post by LTO_Dave
- 38 Replies
- 5752 Views
Last post by templeofspeed
- 1405 Views
Last post by matt1ptkn
- 3951 Views
Last post by Lonestar
- 19 Replies
- 4808 Views
- 20 Replies
- 3410 Views
- 1241 Views
Last post by hugger19
- 47 Replies
- 10617 Views
Last post by johnekb
Users browsing this forum: Mojeek [Bot],
Yandex [Bot] and 10 guests
