rc10 rear arm mounts
General info, Q&A.
SnoopMaxx
Re: rc10 rear arm mounts
Post by SnoopMaxx »
farmer wrote:There is a Co called pargue or something
Like that that all ready makes them kinda pricey
But they are alloy
They also make rims and the make a 1/4 by 12 mm
Hex adapter also
Thx farmer
Yeah, that's the ones I have in the post above
Morten
Morten Max
longboardnj
Post by longboardnj »
But they are alloy
Hex adapter also
Thx farmer
Morten
sorry but the pargue arms are not a option in my book. its a big fail. if you need to mod a "bolt on" part its not the right part and its just a high $ rig part . so sad i started this ? 4 years ago and no real answer to this problem.
SnoopMaxx
Post by SnoopMaxx »
But they are alloy
Hex adapter also
Thx farmer
Morten
I agree with you longboardnj, They are not worth it.
Morten
Morten Max
85Edinger
Post by 85Edinger »
I hear Rouge Element Components has some arm mounts coming soon. Would aluminum mounts increase the chance of damage to the screw holes in the chassis?
yeah, they probably would, and there is evidence of that happening from members on the forum. If they are made, they should be nylon or delrin.
kaiser
Post by kaiser »
delrin. yup.
longboardnj
kaiser wrote:delrin. yup.
so they will be made? who will sell them ? Rouge Element Components? ill wait to see what happens .Rouge Element Components makes some cool looking stuff but i know there has been some fit issues . unless he does 0degree tilt and toe in its real easy to mess this up (what i want so no right and left side plus its the most easy and cheapest way to do it).
85Edinger
Post by 85Edinger »
Even if Rouge Element Components makes arm mounts in nylon or delrin, that doesn't really fix the problem. There's still no steady supply. Is the market really too small for Dynotech or some other small company to make a few hundred a year?
longboardnj
85Edinger wrote:Even if Rouge Element Components makes arm mounts in nylon or delrin, that doesn't really fix the problem. There's still no steady supply. Is the market really too small for Dynotech or some other small company to make a few hundred a year?
Dynotech acted like they were going to do it but instead they just make arms .. in my mind its stupid that alot of people make other parts but no rear arm mounts(rear arm mounts are the only part that ive broke many times on rc10/t rcs).. another problem is people want tilt and toe in.. this not only makes this process harder but then people are asking for different specs.. if someone stops looking at the stock arm mounts i think this can get done.. make a single, centered mounted(stock is offset dual mount)rear arm mount with 0 degree tilt and toe..this way you only have to design 1 rear arm mount cause both sides will be the same part. the real cool part about this is if you bought 2 sets and you bust the right mount 2x you have 2 spares ..does everyone understand what im saying? i know ive been goin on about this alot i just hope the right person gets this info...
SnoopMaxx
Post by SnoopMaxx »
Your actually describing a zero degree Traxxas rear arm mount
like the one used on Nitro rustlers SRT and TRX-3
Integy makes an alloy version
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXZG9&P=7
Here's the 0 degree Traxxas part I used on my SRB build
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ60&P=7
and here's the caster wedge
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJH77
Morten
Morten Max
Guys that are regularly breaking them are racing them and need both antisquat and toe built in. Neither is that difficult with fixtures or CNC programs.
85Edinger
Post by 85Edinger »
Why do you need toe built in? There are lots of hub carrier choices.
Orange
Post by Orange »
I would probably buy several sets if they were 3 degree toe-in AND made in Delrin. No 3 degree, I'm not really interested in any at all. For racing them, its better to have the toe at the mount and have zero at the hub. Its not like I'm going to build shelfers with them. I would much rather use the real thing for a shelfer and in that case, 0, 1.5, 3.0 does not really matter unless its an exact spec box model.
I might be interested in the coolness factor of aluminum for a shelfer that is not built all original spec. and also in that case, it does not matter what degree they are. The Rogue aluminum stuff has some coolness for sure!
Sean Sanchez
Gallery:
My feedback
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
To me the ideal solution isn't to find someone willing to CNC 50-100 parts out of delrin or aluminum with the hopes of selling them at $20-30 a pop, but instead to find someone willing to CNC an injection mold for the parts, send that mold to China to get a short run of 500-1000 parts produced at $1-$4 a piece, then turning around and selling them for $6-$8 a pop.
Just like how aftermarket parts used to produced for the RC10. ;)
Orange
Post by Orange »
I like that idea too!! :)
Sean Sanchez
Gallery:
My feedback
