Will rc10 3 degree rear arm mounts work on an rc10t?
firebird1999us
Post by firebird1999us »
I'm about 99% sure the answer is yes but the seller couldn't say for sure... I bought some rc10gt blocks a few months back that I was told would fit but apparently they are slightly off to mount on an rc10t.
Re: Will rc10 3 degree rear arm mounts work on an rc10t?
Rc10 and 10t are the same. GT are not.
firebird1999us
Thanks!
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
FYI Robinson Racing has 2.5 & 3.5 degree mounts in black. If color is not an issue then the re-re parts may be easier to acquire.
The TX SKUNK
Chewbacca
Has thanked: 51 times
Been thanked: 108 times
Post by Chewbacca »
Where are the 3deg usually applied?
In the Arm mounts
or
in the hubs / hub carriers ?
What Part numbers do I have to hunt for?
Thanks, Tony
*** POWDER - KING ***
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Hi,
The re-release arm mounts are 3 Degrees, ASC 6360, same toe in as the originals on the 10T Team Truck.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXDSXV&P=7
The Worlds rear hubs are 0 degrees, same as the originals on the 10T Team Truck, ASC 7364.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDZF&P=7
Tamlok
Been thanked: 7 times
Post by Tamlok »
Did Associated change part numbers and possibly the specs on some parts?
According to the original 10T manual:
rear mounts, part # 6360 (does not specify degree of toe in, but Google pictures shows 1.5 deg on older packaged parts)
rear hubs, part # 7358, 3 deg of toe in
On my 10T, I have 0 deg mounts and 3 deg hubs. Attached is a picture of the spares I have, notice the part number on the mounts. That is what is now the rear hubs.
The original 6360's are 1.5. The re-release 6360's are 3.
DaveM
Post by DaveM »
Hi,
Team Associated made running changes, they also recycled some part numbers just to make things confusing,
and there was optional rear mounts and hubs.
ASC6360, 1.5 degrees rear mounts are in the #7001 kit.
ASC7363, 3 degree rear mounts are in the #7035 Team kit.
Return to “RC10 Truck Forum”
