Retrofit XX Tranny Chassis Mods
- FasterLouder
- Has thanked: 10 times
- Been thanked: 51 times
I picked up a super clean JRX Pro chassis that I'm going to modernise some,with XX front suspension and a retofit XX tranny.
I have the retrofit tranny-I just need an accurate template of the cut I need to make in the chassis for it to fit.
Can anyone help?
Can anyone help?
All The Way Alive
- bearrickster
- Been thanked: 5 times
Re: Retrofit XX Tranny Chassis Mods
I emailed it to you out side of the site the file was to big. I sent the whole XX retrofit trans manual it has it plus the gearing chart.
- Been thanked: 12 times
I had good luck with the dremel for cutting the hole for the retro trans on a molded chassis. I scratched out the outline with an x-acto knife, then I used the drywall cutter attachment with a suitable bit. It worked really well, the plastic is easy to cut through. I have not tried on a grpahite chassis yet, that would probably be a little harder on the bit.
- bearrickster
I used my Dremal drill press, I set the depth with a flat grinding stone and moved the chassis around till all of the material was removed and with the drill press you will not go through the bottom of the chassis.
- FasterLouder
Thanks for the PDF you e mailed me,Rick.
I really need accurate measurements in millimeters,from the bulkhead and tranny holes in the Pro chassis.
Anyone?
Anyone?
All The Way Alive
- bearrickster
the templet I sent you is full size, you print it cut it out put it on the chassis and mark it?
- 427 Views
Last post by JPAE07
- 2363 Views
Last post by Burniefloyd
- 1293 Views
Last post by losiXXXman
- 184 Replies
- 21189 Views
Last post by RJK33
- 1020 Views
Last post by shodog
- 980 Views
Last post by AllenB.5979
- 34 Replies
- 4585 Views
Last post by JK Racing
- 764 Views
Last post by FasterLouder
