RC10 Team Car restoration
- vanpeebles
Here we go following on from my other thread(Where I bought all kinds of stuff) I now have lots of scrubbed up and cleaned parts all ready to assemble. I should have enough for a runner but also to rebuild a Team car into a runner. Just going to clean up what I have before I start buying new bits like bodies, wheels etc etc. Heres the pics:
Cleaned up metal work:
Cleaned up plastic:
The body looking a bit rough:
I scrapped all the stickers off and polished up the body with t-cut its still pretty rough but looks clean enough now. Sore fingers/nails now too!
Only trouble is I can't see to find any axle stubs I have what looks like the later hubs with the round axles and plenty of normal hubs but no hex axles!
Cleaned up plastic:
Re: RC10 Team Car restoration
switch out those front arms if your going for resto, the team car didnt have black arms
- vanpeebles
Cheers for the tip, thats the only kind of arms I have of that type at the moment. I'll switch em to the multi mix part runner when I get the chance. What colours should the other parts be? Seems to be differences between the manual and various, some black, some white.
- vanpeebles
Just a noob question please (1st RC10 build) The manual says the rear hub carriers should be marked L or R but I can't see any marking and they look identical?
- templeofspeed
If the hub carriers are not marked then they are 0º, as used on the older 'short front arm' cars. This assumes they are the white ones in one of the above photographs... The 0º are not 'handed', and as such fit either side. The correct Team Car carriers are 1.5º per side and the left one is marked with an 'L'. The right is unmarked, but can be differentiated from the older 0º by the thickness of the material where the camber rod ball stud mounts. the old 0º carriers are thinner.vanpeebles wrote:Just a noob question please (1st RC10 build) The manual says the rear hub carriers should be marked L or R but I can't see any marking and they look identical?
- vanpeebles
Ah cheers, I've got four here and they all look the same. I'll fit em and see what it's like. Learning all the time!
- 382 Views
Last post by uscm1488
- 38 Replies
- 8210 Views
Last post by JohnE
- 867 Views
Last post by jeepnut24
- 596 Views
Last post by joe sumasky
- 1598 Views
Last post by THEYTOOKMYTHUMB
- 1461 Views
- 1527 Views
Last post by klavy69
- 995 Views
Last post by pj_elia
Users browsing this forum: Ahrefs [Bot], Google Adsense [Bot], Tbot [Bot] and 44 guests
