Blue shocks
- mrlexan
- Been thanked: 10 times
Re: Blue shocks
Old school. Traxxas had some on the TRX1, but they aren't easy to find and expensive when you do. Losi had some on the XXX Spec.... they are a direct replacement for the JRX2 to XX4 shock bodies. New School... I don't keep up with those too much.
www.gojammedia.com
www.gojammedia.com
Re: Blue shocks
I'm pretty shore That AE make some that are new. for the newer car that they make now.
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
Re: Blue shocks
Asso_man! wrote:yes B4 RTR shocks are blue anodized!
and they are a direct fit for the rc10?
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
Re: Blue shocks
yes and no, you will have to play with external/internal spacers to make them work properly, especially the rear ones.RC Chick wrote:Asso_man! wrote:yes B4 RTR shocks are blue anodized!
Come and visit the stable
Re: Blue shocks
Yeah the rears on my B4 are about 5mm shorter overall with shorter bodies so you may need to get longer shafts? Fronts have the 0.86" body like the B2-B3 but seem to have longer shafts, fibrelyte make a front tower to suit those shocks I think. Or you can also get 1.02" shocks for the front from the T4 RTR.
Re: Blue shocks
I can't find any RTR blue shocks at tower. all I keep finding is the grey olored ones. I found some duratrax ones these are the specs. will they fit length wise. Length: 3.375"/ 85.725mm they are from the evader bx
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Re: Blue shocks
blue AE rears (T4)
http://cgi.ebay.com/New-RC10-T4-Blue-Anodized-Rear-Shock-Set-RC10T4_W0QQitemZ120379809724QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item120379809724&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
I havent found fronts...yet.
- Has thanked: 28 times
- Been thanked: 957 times
Re: Blue shocks
heres the .89 front bodies. i can't find any new kits. you should use a taller front tower with these, though.
http://order.aeteam.net/product_detail.asp?Itemcode=9311B
Re: Blue shocks
pic of the front tower?
Im almost thinking I might use the stock lazer zx5 shocks they are blue and black I have a set already. Think they'll work?
Re: Blue shocks
one of our members makes these on occasion for the .89 shocks.
http://cgi.ebay.com/New-RC10-Buggy-Carbon-Fiber-Front-Shock-Tower-Associ_W0QQitemZ250366192415QQihZ015QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
as for the zx5 shocks, i have no idea. all you can do is try them.
Re: Blue shocks
cool, I hope he does before May. I need one. I think those zx5 shocks will work but it sure would help with that shock tower. only measured they by sight and they are a tad longer than the stock gold ones.
Re: Blue shocks
T4's use 1.39 shock bodies though so the compression travel is limited unless you make a shock tower with a higher mounting hole.JK Racing wrote:blue AE rears (T4)
- 1104 Views
Last post by FasterLouder
- 1737 Views
Last post by Welshy40
- 854 Views
Last post by CBR240
- 913 Views
Last post by Jeep-Power
- 84 Views
Last post by mtbkym01
- 865 Views
Last post by RCveteran
- 122 Views
Last post by juicedcoupe
- 1040 Views
Last post by everlast
