Option House or duratrax shocks?
- transamman908
- Been thanked: 5 times
What is the visual difference between option house and duratrax gold shocks? Came across a few sets and i'm trying to find the difference.
Re: Option House or duratrax shocks?
the easiest way to tell is the the shocks covered with oil will be the duratraxtransamman908 wrote:What is the visual difference between option house and duratrax gold shocks? Came across a few sets and i'm trying to find the difference.
i think the kyosho shock shafts are 4mm vs. 3mm for the duratrax someone correct me if i am wrong
- transamman908
There is some messy ones in there
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
got to use the search, I'm sure Richierich put up a post on the subject.
Anyway, if you can open them it's easy: the duratrax's have only one red plastic spacer at the bottom of the shock-house
Option houses have 2
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
I did a post on Tamiyaclub complete with pictures a while back. See if it helps.
http://www.tamiyaclub.com/forum/index.php?showtopic=42026
- highwayracer
That link has a lot of information...but if you don't want to take the shock apart, there are several things you can look at.
Shock shaft - The duratrax uses a softer metal, so they tend to pit/scratch and rust.
Color - In theory, the duratrax shocks are slightly darker than the kyoshos.
Cap - the flat part of the cap (hole where it mounts to the tower) is longer on the duratrax.
Spring cup - If you lay the cup flat on a table (spring side down), from the side, the kyosho looks like a mountain while the duratrax looks like a top hat.
There are a couple of other things, but they are very hard to describe in words...you just have to see them.
Regards,
highwayracer
Regards,
highwayracer
- RichieRich
LOL! Good disclaimer. Color may not be the most precise way to check. My Duratrax and Kyosho gold shocks look identical in their coloring.highwayracer wrote: Color - In theory, the duratrax shocks are slightly darker than the kyoshos.
Here's another one: I like to give the shock shaft a little wiggle. If you get tons of play, it's probably a Duratrax shock. The single seal allows for more side-to-side movement.
- transamman908
Thanks everyone for the info!!
Also, the bore (interior of the shock body) is usually visually rougher. The Kyoshos will have well finished smooth bore. I have seen some duratrax that looked horrible .-Jeff
- Been thanked: 288 times
Sorry for the thread resurrection, but it *is* relevant. I was initially interested in sourcing a set of blue anodized shocks to spiff up my Turbo Optima, and the Duratrax ones popped up a few times in my research. Unfortunately, the word on those is none too good..."Duraleaks" made me chuckle!
Anyhow, Yeah Racing has blue anodized shocks in the necessary lengths--70mm and 100mm--that look like they'd work, and they have the threaded spring retainer too, which is cool. Question is, are they decent & good performing shocks? Anyone use them?
I'm itching to pull the trigger on these, but not if they're junk. My Turbo Optima is going to be a runner, not a shelf queen, and I'm going for a blue anodized theme eventually. I'll not bother if anyone can confirm these Yeah Racing shocks aren't up to the task.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=120587169147&ssPageName=STRK:MEWAX:IT
Thanks!
Thanks!
I wonder how the Yeah Racing shocks compare to the 3Racing shocks. The price on the 3Racing shocks is certainly attractive at about $23 for a complete set of fronts and rears.
http://www.3racing-parts.com/shop/kyosho-lazer-zx5-chassis-aluminium-front-and-rear-damper-blue-color-for-kyosho-lazer-zx5-3racing-zx501bu-p-10001396.html
Also, does anybody know if Kyosho put out a rebuild kit for the Platinum shocks? If so, what was the part number? Or another source for O-rings for the Plats. ?
I asked about the Yeah Racing shocks a few weeks ago, but it seems nobody has used them...at least not in the Kyosho section. The Y.R. units are available in the exact sizes to fit my Optima, but I don't want to waste money on them if they're leaky or don't perform smoothly.
i have used yeah and 3 racing. niether of them are very nice. the inner bores aren't very smooth which makes them feel stiffer then they should.
the old tamiya yellow cva's are way better than either of these two stinkers. IMHO
i stopped looking for budget shocks because they both stink. now i only use associated, losi or tamiya trf's.
Thanks kaiser...myself, I'm not trying to find budget shocks, I'm trying to find blue anodized shocks to go with my upcoming blue Optima build....not having any luck so far! Any suggestions?kaiser wrote:i have used yeah and 3 racing. niether of them are very nice. the inner bores aren't very smooth which makes them feel stiffer then they should.
- 19 Replies
- 2943 Views
Last post by Mad Racer
- 2190 Views
- 2139 Views
Last post by coxbros1
- 1167 Views
Last post by Bormac
- 757 Views
Last post by Mr. ED
- 401 Views
- 1156 Views
Last post by Lowgear
- 761 Views
Last post by johnnyboy
Users browsing this forum: No registered users and 16 guests
