** Build of the Month Contest - May 2024 **
Moderator: scr8p
- Has thanked: 28 times
- Been thanked: 957 times
Open To Any Manufacturer!
OK, this will be the thread for the May 2024 Build of the Month Contest.
GOOD LUCK!!!
** Place Holders **
GOOD LUCK!!!
** Place Holders **
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
Re: ** Build of the Month Contest - May 2024 **
- Has thanked: 1013 times
- Been thanked: 472 times
Here is my 12e. It cleaned up really nice. I made a new radio tray. I was able to get the motor in nice running condition; it has the original Edinger in it. It's nice to see what kicked off so many people in the hobby.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
My glorified Rustler.....
- LurkingCAT
- Has thanked: 102 times
- Been thanked: 154 times
Kyosho Progress. New built with electronics.
Everything working perfectly included the four wheel steering and torsion spring assisted front suspension
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
I've been busy this year but I'll play.
This started out as a $25 Frog parts car, then evolved into the Brat/Blackfoot hybrid you see here.
The original Frog chassis, transmission side plates, and battery holders have all been painted. The front and rear control arm mounts, MSC mount, and front body mount have all been polished.
The rear uses the middle Frog gearing, "Old Frogshot" modded diff, and re-re Blackfoot CVD's. The shocks are Duratrax with Tower springs and Frankentruck plastics.
The front is a Frog/Blackfoot hybrid, used BF carriers and uprights (modded for reduced bump-steer) with a Frog style spring system. Springs have been replaced with lighter and longer versions.
Other upgrades include AmPro center servo mounts, rear skid plate, and shock mount/body mount braces (for BF).
Electronics consist of a Tamiya receiver, Hobbico servo, Dynamite esc, and Tamiya motor.
Wheels are from a Stadium Blitzer (slightly modified fronts), with Blitzer front tires and Trenchers on the rear.
Click on pics for better resolution.
- radioactivity
- Has thanked: 345 times
- Been thanked: 516 times
Kyosho Outrage
I completely disassembled and thoroughly cleaned this car, I'm not sure it was ever run.
A few more pics. https://www.rc10talk.com/viewtopic.php?p=560878&hilit=outrage#p560878
Chuck
Chuck
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
- morrisey0
- morrisey0
Nice little race popping up! Bumping this to get into New Posts.
- morrisey0
April had 65 votes. May, within 5 days of polling closing, has 47 votes.
Another 18 votes could change the whole race!!
Get your vote in!
Get your vote in!
