Total newbie here. RC10 brain trust: What are the go-to tires (and maybe replacement wheels) for neighborhood bashers? I’ll be running the 40th re-re as I would have 35 years ago in a mixed urban environment (parks, ball field, streets, curb jumping, etc). My Hornet and Frog knobbies were half bald in weeks. Just looking for something that’ll get thr RC10 up/over/through it all a little better.
Talk to me like a 10 year old. I know nothing.
Tire/wheel recommendation
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: Tire/wheel recommendation
Some JC Racing 2.2 wheels and modern tires will be your best bet. They'll probably look a little odd on a short arm car.
Just note that the fronts are available in two widths. The narrow looks more "correct" on a vintage car but tire selection is limited.
The wide front has a large selection of tires. A 4WD front tire can even be used, although it will balloon a little.
Jconcepts has some tires and wheels in the 1.7/1.9 sizes (they don't fit the factory wheels!) but they are smaller versions of their race tires. They are soft and will wear fast.
- Has thanked: 20 times
- Been thanked: 16 times
Thanks @juicedcoupe
I see the brand JConcepts popping up a lot on searches.
My TT-02B has Tamiya Dual Block K tires, which look somewhat closer to the J Concepts Double Dee or Barcode tires. The Tamiya tires seem not great on any particular surface I run but acceptable on all of them, but that could also be that its my first 4WD car and as such is a lot easier to control.
On the other hand, the Frog and Hornet knobby tires are simply horrible the moment I transition to any hard surface like asphalt, cement, or even hard packed dirt really when I full-speed-ahead the throttle.
Probably a rally type tire is best as a jack of all trades, master of none... but I'm not seeing anything quite like that for the RC10 wheels sizes, so looks like I may be venturing into a new wheel set to accommodate something bigger up front.
The search continues....
- Has thanked: 1013 times
- Been thanked: 472 times
I am running 2.2" wheels on my rc10 with traxxas anaconda tires for general bashing. The size looks weird, but the extra ground clearance make for better bashing. A&L (factoryworks) makes real wheel 1/4" axle to 12mm hex adapters so you can run modern hex rear wheels without having to modify the buggy.EmptyHand wrote: ↑Sun Apr 21, 2024 6:44 pm Thanks @juicedcoupe
- 20 Replies
- 3666 Views
Last post by Charlesmtb
- 1513 Views
Last post by NomadRacer
- 828 Views
Last post by Twin Detonator
- 21 Replies
- 3165 Views
Last post by delsami
- 1244 Views
Last post by mikedealer
- 1198 Views
Last post by m2fit4u2
- 750 Views
Last post by Brandon G
- 1412 Views
Last post by pumpkinfish
Users browsing this forum: Facebook [Bot] and 42 guests
