Fitting a Slipper to Ultima ST, Some Advice Needed...
- Has thanked: 120 times
- Been thanked: 94 times
I'm looking to fit a slipper to an Ultima ST. I'd like to get rid of the proprietary gear. Neither slippers nor gears are common to come by these days. Does anyone know of a slipped that uses a metric pin drive? T*****s is hex drive, B/T4 is slotted, Kyosho RB uses a flat in the shaft. What pressure plates can still be found that accept a pin?
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: Fitting a Slipper to Ultima ST, Some Advice Needed...
Different Traxxas vehicles used different kinds of input shafts. I think that there was hex, pin, and DD.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Know anyone with a modern tra**as 2wd? The newer ones use pin drive but have a stoopid offset gear. Drag race concepts make a pin drive slipper eliminator that uses standard gears.
- 1214 Views
Last post by stephenianjames
- 1465 Views
Last post by peetbee
- 1335 Views
- 30 Replies
- 2942 Views
Last post by Volumiza
- 2193 Views
Last post by mrlexan
- 759 Views
Last post by kaiser
- 20 Replies
- 2370 Views
Last post by moj
- 603 Views
Last post by Dadio
Users browsing this forum: No registered users and 21 guests
