Where to find metal gears for rc10 B3 differential and maybe the stealth transmission?
- Regular Member
I have a two year old now and have gotten back into RC. I have my old childhood rc10 B3. I put in a brushless motor with amazing results but I would like to beef up the necessary bits for handling the new power. Advice is much appreciated
- Has thanked: 28 times
- Been thanked: 957 times
Re: Where to find metal gears for rc10 B3 differential and maybe the stealth transmission?
As long as you're not overpowering it, it's really unnecessary.
- mAdMan
- Has thanked: 162 times
- Been thanked: 98 times
This is your part number for the idler (9360) per associated’s websiteObsidiancobalt wrote: ↑Sun Feb 18, 2024 3:25 pm I have a two year old now and have gotten back into RC. I have my old childhood rc10 B3. I put in a brushless motor with amazing results but I would like to beef up the necessary bits for handling the new power. Advice is much appreciated
https://www.associatedelectrics.com/teamassociated/parts/details/9360-ASC9360-idler_gear_molded/
Here is the aftermarket metal idler gear
https://www.ebay.com/itm/384237723404?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=LdYFTN_MR9-&sssrc=4429486&ssuid=d_l0pQBTRBK&var=&widget_ver=artemis&media=COPY
Keep your diff gear plastic. Or risk more expensive driveline parts.
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
TBH, the B3 has always been my favorite AE buggy. I've beatenen the snot outta mine with few breakdowns that have already been mentioned. I've used all the metal parts in the tranny at one point or another and end up with stock in the end. I've put some really hard runs on it with some excessive stupid power and the factory stuff always perserveres.
Otherwise my only hardest runner has front RPM arms and steering blocks as I was running out of carbon ones with that damn tube that kept running out in front of me on the front stretch...
- Has thanked: 1013 times
- Been thanked: 472 times
A metal diff gear may be hard to find. The gear ratio is 2.40 the custom works 2.40 parts are compatible for the most part.Obsidiancobalt wrote: ↑Sun Feb 18, 2024 3:25 pm I have a two year old now and have gotten back into RC. I have my old childhood rc10 B3. I put in a brushless motor with amazing results but I would like to beef up the necessary bits for handling the new power. Advice is much appreciated
A properly built rc10 stealth handles a lot of brushless power. By the time you are making enough power to strip out gears you are likely to actually shatter the car on a crash. This is what happened to my T3 basher. The transmission is fine. The rest, not so much.
- Chillout47
For retro racing I upgraded my B3 to a b4 top shaft and slipper assembly, it's a straight swap and takes the strain out the single slipper pad that comes in the kit.
- 2905 Views
Last post by Lowgear
- 153 Views
Last post by mAdMan
- 883 Views
Last post by templeofspeed
- 2143 Views
Last post by yellowdatsun
- 586 Views
Last post by Erich Reichert
- 770 Views
Last post by flipwils11
- 1413 Views
Last post by mjtown
- 1561 Views
Last post by shodog
Users browsing this forum: DotNetDotCom.org [Bot], Tbot [Bot] and 44 guests
