Were there any changes from 7444 to 9824?
- mAdMan
- Has thanked: 162 times
- Been thanked: 98 times
All I have for rear towers for a 10b build is part number 7444. I cannot seem to find any differences to 9824. What’s up with that?
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Re: Were there any changes from 7444 to 9824?
Most likely the addition of the holes in the shock tower valley and likely being made of a more plastic like material.
- mAdMan
This one has the holes but I could see it being more glass fiber reinforced or carbon like. I would guess now looking again that is the “composite” part. I’ll know when I build it. I’m going to use it for the 10b. Thank you!
- Dangeruss
- Has thanked: 148 times
- Been thanked: 553 times
#7444 is the standard composite tower that came on T4's.
#7445 is the carbon tower that came on the FT T4's.
#9824 is the soft plastic tower that came on SC10's.
Kind of a Goldilocks, soft, medium, hard arrangement with the #9824 equal to RPM plastic, #7444 standard Associated plastic, then #7445 obviously the hardest. Color is different between them, #9824 is the darkest black, #7444 is a lighter black, #7445 is nearly grey. They also feel different, increasingly more "dry" with each step up in strength. Hole placement is the same across all three.
- Has thanked: 1013 times
- Been thanked: 472 times
Didn’t they also change the mount points for the large bore shock caps to allow for more clearance.Dangeruss wrote: ↑Tue Feb 13, 2024 4:20 am #7444 is the standard composite tower that came on T4's.
- Dangeruss
Nope... large bore models just came with slightly thicker upper bushings.
