Hobbywing 1060 ESC - Brushed Motor - No Brakes, No Reverse
- GreenBar0n
- Has thanked: 578 times
- Been thanked: 262 times
I recently finished a Tamiya M-06 VW Bus model, and it came with the 1060 ESC and a standard 540 motor.
I have a Spektrum DX5C with the 5 channel SR6100AT Rx. I've got everything working now, except the brakes and reverse.
The Tx is at all default's, I created a new model a few times now with the same results.
The 1060 ESC is set for F/B/R - which should be forward, brake, reverse.
I tried to get the 1060 LED's to show up in this video, but the angle is wrong, the lights behave correctly, except no brakes and no reverse LED's respond on the ESC, only the forward flashing and solid modes.
Any idea what's wrong here?
- GreenBar0n
Re: Hobbywing 1060 ESC - Brushed Motor - No Brakes, No Reverse
After playing around with this for a while, I got it to work.
I had to create a new model in the DX5C, Bind the SR6100AT to it, then there is a calibration sequence that has to be done immediately after initiating the Bind, by pressing throttle full/neutral/reverse, then left, middle, right on the steering, and then the Rx will Bind. This was not mentioned in the single-fold 1060 manual in the Tamiya kit, and I previously was able to Bind many times successfully without the Reverse being calibrated.
I'm new to ESC's, so I'm still figuring this out, used to MSC or nitro.
Also having this exact same problem with my Novak Rooster and RC10, no brakes no reverse, hoping it's something similar to this problem here and an easy fix as well.
- Has thanked: 2287 times
- Been thanked: 1994 times
Unfortunately the Rooster probably has a blown Break FET , not too hard to replace .GreenBar0n wrote: ↑Fri Jan 05, 2024 12:25 am After playing around with this for a while, I got it to work.
- GreenBar0n
I did get the Rooster working, it was a calibration issue with the ESC\Rx, and it may have been a capacitor in the wrong spot too. Thanks!
- Regular Member
Thank your for the solution for this... Spektrum was no help.
- Has thanked: 65 times
- Been thanked: 46 times
No surprise there. They are useless and when they are helping you they are condescending and rude.tcookie1034 wrote: ↑Thu May 16, 2024 6:03 pm Thank your for the solution for this... Spektrum was no help.
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
Those two things aren't really needed anyway, so get going!
- 1023 Views
Last post by RCveteran
- 1728 Views
Last post by Bottom Feeder
- 502 Views
Last post by gwandson
- 5079 Views
Last post by AYKBOBCAT
- 20 Replies
- 4649 Views
Last post by blk05wrx
- 3166 Views
Last post by spru
- 828 Views
Last post by uniquenamehere
- 854 Views
Last post by knucklebuster
