Hello all. '97 Inferno 10 owner here. Converted to brushless setup and in need of part.
Trying to find alternatives to the OTW-10 Servo Saver kit. I got a set about a year ago and no longer can find any. Does anyone know an alternative? Aluminum?
Thanks!
OTW10 alternative?
- Has thanked: 120 times
- Been thanked: 94 times
Re: OTW10 alternative?
You could likely adapt a Factory Works /A&L steering kit. Jeff can speak to when those might come back in stock. With a good metal gear servo you can also get rid of the servo saver. This is assuming you are doing typical vintage running and not sending your Inferno off skate ramps.
- Has thanked: 822 times
- Been thanked: 2418 times
our steering kits will be into late january at the earliest. I would look at adapting one from the rere optima mid, they are tough and could likely be adapted without too much trouble
Factory Works website
Thank you both. No skate parks for me. Just backyard ripping with dogs in chase.
I will keep on eye on the release and look into the Optima Mid setup. Metal servo was the first to be installed.
- 578 Views
Last post by THEYTOOKMYTHUMB
- 645 Views
Last post by juicedcoupe
- 26 Replies
- 2336 Views
- 1120 Views
Last post by teman
- 993 Views
Last post by adam lancia
- 19 Replies
- 2636 Views
Last post by knucklebuster
- 1513 Views
Last post by markt311
- 716 Views
Last post by vintage racer
Users browsing this forum: Google [Bot] and 18 guests
