Hi at all,
i find this Missiler and i see the tyre set are not the original set.
This tyre set surely are hobby grade, probably the front rims are the Tamiya grasshopper? I'm not shure.
Whre i can find a tyre set like this one? It's for a restoring my Missiler, the original tyres in my one are worn.
Thanks at all
Libra
Yonezawa missiler hobby grade tyre set identify
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Yonezawa missiler hobby grade tyre set identify
Those were the same platform as the monogram thunder, and shares parts minus the body with the monogram lightning. These were also sold under bandai name. In the USA monogram sold parts, not sure if bandai and others did elsewhere. Here is a set of fronts for example that is on eBay currently. https://www.ebay.com/itm/275925426443
Factory Works website
Thanks Gomach,
this is like the original one, but i want to change it.
I try the grasshopper set.
Thanks.
Libra
Thanks.
Libra
Ahh I misunderstood, I thought you were trying to restore yours. In that case yes, grasshopper series wheels front and rear should fit fine. You may need to slightly trim the adapter for the rears to fit, as mentioned by bolink
Thanks Gomach.
Yes i restore my one, but i want install a grashopper tyre set.
Thanks for the bulletin you add, to modify the rims.
Thanks again,
Libra
Thanks again,
Libra
- 2047 Views
Last post by Mr. ED
- 99 Views
Last post by TycoTamiya4eva
- 2196 Views
Last post by vwjuice
- 951 Views
Last post by peetbee
- 20 Replies
- 1360 Views
Last post by tecnica2001
- 639 Views
Last post by stingerrray
- 763 Views
- 1775 Views
