for those not on Facebook... JC Racing edition
- Has thanked: 822 times
- Been thanked: 2418 times
JC has molded the conversion box I created that uses a B6 ball or gear diff and a DR10/SR10/RB10 slipper. This case will allow the buyer to bolt it right into any RC10 as it has both stealth and 6 gear holes, and will fit either trans brace. Keep an eye on their website for these
Factory Works website
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: for those not on Facebook... JC Racing edition
I predict a lot of oldie RC10 and RC10T will be getting retrofits.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Very cool piece
Hey Cru ! Go balls out
- RogueIV
- Has thanked: 1119 times
- Been thanked: 459 times
I guess I'm holding off on my next order for a little bit till those drop so I can dust off the RC10T.GoMachV wrote: ↑Wed Nov 15, 2023 1:28 pm JC has molded the conversion box I created that uses a B6 ball or gear diff and a DR10/SR10/RB10 slipper. This case will allow the buyer to bolt it right into any RC10 as it has both stealth and 6 gear holes, and will fit either trans brace. Keep an eye on their website for these
- RC10superfan
- Has thanked: 79 times
- Been thanked: 10 times
wow, this is great! I’ll be getting some of these transmissions!GoMachV wrote: ↑Wed Nov 15, 2023 1:28 pm JC has molded the conversion box I created that uses a B6 ball or gear diff and a DR10/SR10/RB10 slipper. This case will allow the buyer to bolt it right into any RC10 as it has both stealth and 6 gear holes, and will fit either trans brace. Keep an eye on their website for these
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Hopefully they do yellow like in the picture to match the A&L steering
I want to get my hands on one of these. I would be happy to test it out. Much needed as OG parts are kind of weak.
- Westcoast10z
- Has thanked: 4 times
- Been thanked: 16 times
Yooo these are available now! Just ordered an ivory one! Ivory, white, black, yellow and blue available
I have a Novak problem....
here is a link to the page, they have listed all the required parts as well. https://www.jcracingproducts.co.uk/associated-rc10-transmission-case
- Has thanked: 1013 times
- Been thanked: 472 times
Will the DR10 diff work in this case or only the b6? Which idler works?GoMachV wrote: ↑Wed Nov 15, 2023 1:28 pm JC has molded the conversion box I created that uses a B6 ball or gear diff and a DR10/SR10/RB10 slipper. This case will allow the buyer to bolt it right into any RC10 as it has both stealth and 6 gear holes, and will fit either trans brace. Keep an eye on their website for these
The list on the website has all the part numbers but it's a 26t idler from the B6 series. You can use a dr10/rb10/sr10 diff but they are narrower so you will need about 1mm of shims per side. Unless you already have one it's more expensive to build so it's recommended to just use the B6 diff
- RC10superfan
Just bought a gearbox. Looks great! Can’t wait to try itGoMachV wrote: ↑Fri Dec 08, 2023 12:40 pm here is a link to the page, they have listed all the required parts as well. https://www.jcracingproducts.co.uk/associated-rc10-transmission-case
- Westcoast10z
What is the length of the top case screw, the one that goes all the way through? I mistakenly assumed the stock screw would fit, but it is slightly too short. Kit screws fit everywhere else, though. Thanks!
- Been thanked: 4 times
Looks like 1 3/16" on my vernier, measured shank only, not the head. This leaves enough thread protruding (into the spur?) to fit a nut if necessary. The black screw in the pic is one I bought from Dubro and is 4/40. I'd just do that and cut it if you have all black screws.
Jeff if you're out there, thank you so much for doing this! They are a bit dear in price, but I placed a big enough order that somehow the price of everything was reduced. Not sure it this is just a volume discount but if others are wary of the cost, play around with the cart contents from JC, there is no shortage of spares. What a time to be alive! M4 threaded universals mean we can finally use common serrated aluminum wheel nuts, and that is just awesome. I never thought I'd see the day we could build a NEW RC10 graphite buggy with all moulded nylon parts. I shudder to think of the total cost, but there it is. Appologies if my photo skills are lacking!
Thank you, it was a long work in progress for me- and I gave the file away so it could be done right. I am not affiliated at all except that he was able to take my work and make it... work
- 746 Views
Last post by THEYTOOKMYTHUMB
- 869 Views
Last post by GJW
- 2213 Views
Last post by alien3t
- 26 Replies
- 3379 Views
Last post by Orange
- 2773 Views
Last post by NomadRacer
- 529 Views
Last post by Dessertrat
- 88 Replies
- 7310 Views
- 734 Views
Last post by shodog
Users browsing this forum: No registered users and 44 guests
