Dadio's latest dumb question
- Has thanked: 2287 times
- Been thanked: 1994 times
Ok today's dumb question is about the very early steering wheel style Transmitters , it's obvious how you did the steering on them but unlike the later "trigger and wheel" radios that we still have today it's hard to see how the throttle was controlled , or if I'm guessing right the throttle control looks not much bigger than the trim .
So how was the throttle controlled ?
- 1300GT
- Has thanked: 331 times
- Been thanked: 272 times
Re: Dadio's latest dumb question
There's a throttle lever on the right hand side of the transmitter which isn't visible in the picture. You can see it here in this picture. I had one years ago and I found it terrible to use after getting used to conventional stick radios.
I guess modifying them to accept a slot car controller was a huge improvement.
Chris.
Toys.............they are!
- Lowgear
- Has thanked: 78 times
- Been thanked: 596 times
I have one, and it's indeed very awkward to use. Like 1300GT mentioned... people modified them by screwing a slot car controller to the backside, and connected the throttles between the two via a bellcrank and rods. Parma even sold an actual conversion kit.
Here's what a modified setup looks like: https://www.tamiyaclub.com/showroom_model.asp?cid=126922
Also in the same vein: https://www.rc10talk.com/viewtopic.php?t=46504
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
that stick radio conversion is something else
- Has thanked: 822 times
- Been thanked: 2418 times
You would cradle the radio in your left hand, with your index finger wrapping around to the throttle. Uncomfortable compared to a pistol grip but honestly not that terrible imo
Factory Works website
- Has thanked: 1032 times
- Been thanked: 488 times
Brilliant!
I had one (standard, not modded). It was my first radio actually. It was very awkward! You really needed 3 hands to operate it smoothly.
If you can steer with your left hand, hanging it from a lanyard (like an RC plane radio) would probably work well.
I had seen pictures of the side with the controls but found it hard to believe that's what they actually did , thanks everybody ! I'll see if I can think of another dumb question soon
This kid is holding it properly
- 1300GT
No wonder I struggled with it. It's not designed for all the Southpaws, Mollydookers and Goofy-footers.
Chris.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Did anyone make these with the controls swapped?. i.e. throttle stick on the large face, steering wheels on skinny side. I think that could actually be pretty comfortable.
- Has thanked: 60 times
- Been thanked: 83 times
Would've made sense to have your thumb on the wheel next to steering as throttle and the side slider to be trim.
Looks like it tuned into radio Luxembourg as well.
- 415 Views
Last post by Dadio
- 818 Views
- 1230 Views
Last post by Eau Rouge
- 1676 Views
Last post by tamiya_d1_junky
- 569 Views
Last post by Dadio
- 480 Replies
- 47191 Views
Last post by silvertriple
- 1782 Views
Last post by Dadio
- 687 Views
