Hot Trick Red Fox (Tamiya Fox conversion)
- Radioflash8
- Regular Member
- Has thanked: 10 times
- Been thanked: 7 times
I picked this old thing up at a swap meet, does anyone know what exactly these are and what the scoop is?
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: Hot Trick Red Fox (Tamiya Fox conversion)
Hot Trick was an aftermarket parts company that most used flat metal plates (I think typically aluminum) for replacement parts. That looks like a Tamiya Fox that got the plastic chassis replaced with the Hot Trick kit.
Well, maybe is started out as a Tamiya Fox. There's a few RC10 parts in the mix too.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
From my experience, those esc's prefer a transmitter with 50/50 range.
Not saying thats the problem, just something I've noticed.
- Radioflash8
- Regular Member
Thanks for the info, the transmission, wheels, and some of the front a-arms look like they came from a Fox. It has metal rear dog bones which I'm not sure where they came from.Frankentruck wrote: ↑Tue Jun 06, 2023 5:47 pm Hot Trick was an aftermarket parts company that most used flat metal plates (I think typically aluminum) for replacement parts. That looks like a Tamiya Fox that got the plastic chassis replaced with the Hot Trick kit.
It wouldn't power on when I plugged my battery in (7.2 Nimh), do they have a switch that I missed or are old Futabas always on?juicedcoupe wrote: ↑Tue Jun 06, 2023 7:01 pm From my experience, those esc's prefer a transmitter with 50/50 range.
- Has thanked: 31 times
- Been thanked: 39 times
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
Pretty much a "Holy Grail"...I hope u do it justice with a full documented resto!...if not u need to sell it to me and I will!
- LurkingCAT
- Has thanked: 102 times
- Been thanked: 154 times
Hi there, really cool to see this Red Fox! I had a Fox in the 80's which soon got a full Hot Trick conversion with RC10 shocks and Thorp drive line. Custom fees and trades profit made Hot Trick awfully expensive here, and to my knowledge I was the only one in Norway to have this platform. Still have my old Red Fox (luckily never sold it!), and later I've aquired two other cars. One I'm using for vintage racing - really fun car to drive. A picture of one of mine is in this thread: http://www.rc10talk.com/viewtopic.php?f=33&t=27601
- Radioflash8
- Regular Member
It really wouldn't need much as far as I can tell, just new tires/wheels and a Fox (or "Novafox") shell, shock oil...just a bit annoying that Tamiya ended the re-release.
- Has thanked: 822 times
- Been thanked: 2418 times
The rere novafox is coming back soon. There is a preorder for them that I've been on for a few months. I think it said they are due in August, meaning part should follow shortly.
Factory Works website
- LurkingCAT
Just want to give a second opinion on body work for the Red Fox. The original Fox body is small compared to many other 1/10 scale buggies, and designed to wrap around the original monocoque chassis. As you can see it looks something like a 1/11 scale besides a Protech for the RC10. The Hot Trick kit turn the car much closer to a RC10 than a Fox, and the original Fox body is simply a terrible fit - short, much too narrow, too high round your battery section not covering the sides of this area at all and too low over the rear shock struts (not to mention the wing). Anything for a standard RC10 platform is way better, along with the body you already have.
Seems to be more or less a brim full conversion. Upper and lower rear arms, chassis, steering kit, front end and shock mounts. Even looks like you have the Hot Trick dog bone conversion for the original diff, unless it's Thorp. Thorp has both the dog bone conversion for the original diff and the ball diff. Only thing from Hot Trick I can't see is the optional radio plate.
All the best for your Red Fox project
- Radioflash8
- Regular Member
Thanks for the heads up, iI'd like to replace the tires and do maintenence for now, otherwise I want to keep everything else original.LurkingCAT wrote: ↑Wed Jun 07, 2023 2:32 pm Just want to give a second opinion on body work for the Red Fox. The original Fox body is small compared to many other 1/10 scale buggies, and designed to wrap around the original monocoque chassis.
- Has thanked: 2287 times
- Been thanked: 1994 times
I never know if I'm supposed to laugh, cry or love Hot Trick stuff but I really like this one .
- LurkingCAT
Posting up two pictures of my runner. First picture of a setup from a race on carpet where only original wheels were allowed. Used a fresh set of Schumacher full spike yellow and removed the spikes for carpet racing. Would really recommend the Schumacher tires for the original Fox wheels - for the US still available from amain hobbies – perfect fit for the Fox wheels.
Second picture from outdoor race on astro turf where 2.2 wheels were allowed. You can also get golden 2.2 Fox wheels from jcracing.
- Radioflash8
- Regular Member
Thanks for the tip, I do want to use mine as a runner and seeing your nicer example makes me feel better about driving mine occasionally.LurkingCAT wrote: ↑Fri Jun 09, 2023 3:14 am Posting up two pictures of my runner. First picture of a setup from a race on carpet where only original wheels were allowed. Used a fresh set of Schumacher full spike yellow and removed the spikes for carpet racing. Would really recommend the Schumacher tires for the original Fox wheels - for the US still available from amain hobbies – perfect fit for the Fox wheels.
- 1855 Views
Last post by rangerg
- 3197 Views
- 94 Replies
- 8222 Views
Last post by MelvinsArmy
- 19 Replies
- 3151 Views
Last post by Mr. ED
- 1289 Views
Last post by CNA75
- 1016 Views
- 28 Replies
- 3583 Views
Last post by Tuff240
- 51 Replies
- 5986 Views
Last post by Prince Steve
