Another Nichimo project... or maybe two, actually :)
- silvertriple
- Has thanked: 593 times
- Been thanked: 860 times
Hi everyone,
After the Spirit FF which have a lot in common with the Vantage FF (I got the data for it, so it should be possible to do it at some point), and both Midships and Pegasus Exceed, if I want to complete the chassis collection, I have 2 which I need to tackle...
Fortunately, one guy proposed me two cars recently, and they were the two missing cars missing in the Nichimo buggy range :
A Cosmo Shooter - 2WD - kit n°6, with its box, and complete (the driver is in one of the boxes)
A Luminous - 4WD - kit n°5 without the box and the bodyshell, and a broken steering servo...
I check the instruction manuals, the construction is modular, and even lot of pages in the manual are the same... My target is to model both chassis, and add them to my virtual Nichimo collection
Workplan :
- tear down
- CAD model of common things
- CAD model of 2WD specific parts
- CAD model of 4WD specific parts
I can already tell there is lot also in common with the 4 other kits, even without having tore them down...
Workplan :
- tear down
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: Another Nichimo project... or maybe two, actually :)
If one of them has a broken servo , well it's done for really you could send it my way LOL
Pretty jealous , have fun
- silvertriple
it should be fun... I pull the trigger on those only because then I will have all Nichimo parts . It's the first time I get cars without any plan for them...
- silvertriple
I can confirm the Luminous is indeniably a Nichimo : there is a **** lot of screws to get it down to parts...
I will need to do the same for the Cosmo Shooter, but I will proceed to the cleaning of the parts of the Luminous first. It's much more confortable to model clean parts
- silvertriple
While the gearbox print test is in progress for the Super Wheelie/Big Bear, I did some cleaning on the Luminous parts...
Ultrasonic cleaner, water and dish soap, 50°C, 30 minutes bath with 10 minutes ultrasonic waves activated...
Parts look almost like new... I've not cleaned anything on the transmission parts (for most, I don't need to model them as I have the front and rear diff from the Spirit FF and the LSD (limited Slip Differential) from the 443WDS)...
That should allow me to work on the Luminous CAD model very soon...
- silvertriple
When I went back from the office, the Luminous were sitting next to my computer with the caliper...
I started by the rear gearbox...
Measured the overall length, positioned the center hole, then the diff hole, and derived the rest from there... The distance between the two key holes is the same than on the Spirit FF and Exceed front gearbox, unsurprisingly...
Once the right side was done, I did a mirror and worked out the left side
Once there, I had a few checks, and I noticed that the shell thickness is variable : it should 12.25 mm deep in the center (1.75m thickness) while the rest is 2mm thick. I check on the front gearbox, and it is 12mm deep in the center (like on the Spirit and Exceed, so it should not be an issue, really - just have to make it proper in shimming). I still need to make everything that close the gearbox and complete it, in both 4WD and 2WD as while thoe part are common, some are distinct between the two models in the gearbox...
- silvertriple
I spent the night sleeping with an issue in mind, I didn't now where it was when going to bed...
Today, I checked. The diff had not enough clearance based on what I see with the diff in the gearbox : the diameter had to be bigger inside, and the thickness is not in cause. This means the diameter is wrong. And the diameter is made from the center position and the extreme point which is 100% sure. My center position is wrong then : and the mistake is because a sign in the calcul of the position of this hole. The spacer is shorter in the gearbox than for the Exceed, that should have ring the bell...
Anyway corrected the sketch and had a look again... And it became clear that my tangent arc is not right, as we have likely a double curve as the diameter is bigger, which means as well the tangeant on the circle is taken lower...
it's the same, but different . I'll have to get a print to see if I can reproduce the exact spline on the top, but it's not too much important...
- silvertriple
Did not post much those days... Lack of motivation it seems, plus a bit too much of work in the office...
Anyway, yesterday, I worked on the front gearbox left side...
I started by putting all the key measurements in a single sketch, did a few extrusions, chamfer, and lofts, and I had my part ready to shell...
On the other side, I had this...
I first worked the inside...
Then move to the other side... The suspension supports remain to do...
And that was quite fast to do...
The right side was started with a mirror from the left, were I did rework whatever was required using extrusions...
And here is:
I'm not sure what I tackle next yet...
And here is:
- silvertriple
Nichimo Luminous and Cosmo Shooter arms are prone to deformation including for display usage, and this even if the wheels are not touching the ground... All of them are deformed. I did model them without the deformation, and that is where we are all superior to any scanner which would have included the deformation without even considering that as an issue...
I started by the front
Then made a copy paste as new to change the few measures required to be changed plus review the following operations to make a rear arm. That took me about 5 minutes...
C-hub and carriers were easy to do with a limited number of sketch for each...
On the suspension it remains the upper arms and steering arms to model, as well the pivot balls and joints...
Speaking about suspension, I made the shock tower which comes on the front gearbox... It's a bit complex, and required a bit more than 10 sketches to get there (I might have done less, maybe, but I've been lazy )
The fact is this part allowed me to check and review the position of the shock tower fixation on the gearbox, which was the only doubt I had...
- silvertriple
The chassis itself is a nightmare to measure, in all the directions, with a similar type of complexity as the Marui Samurai chassis... I had some checks, and what I thought initially to be a common plan was not...
In terms of approach, I decided to do one single sktech to fully define the profile, then did some extrusions from there and, applied the chamfers, cut from other plans and so on... Few pics with the different steps :
Once there, I got the holes applied...
And the next step was to deal with all the features on both sides...
Once the left side was done, next step was to make a mirror and to do the difference appliable to the right side (which will be retaining nuts for the transversal long M3 screws).
- silvertriple
With the two chassis halves in hand, it is time to make some joints and check everything is lining up...
A few minimal corrections here and there, and here is what I have
I have a small 1 mm doubt...
But having done checks on the gearbox, it seems that it is likely this way in the car... I checked the joint freedom degrees, and it is largely inside what is possible, so there is fair chance this is correct... (but I can't help thinking that it could have been much better to have this lined up)
That chassis looks like a beast to measure giving me Samurai flash backs
- silvertriple
Yeah... Exactly what I thought, with a extra bonus ball for the half millimeter or quarter millimeter measures for this Nichimo... At the end, the very few times I had a plain millimeter measure, I checked twice or three times
- silvertriple
After my last post, I worked out the Bumper...
And it was very quickly added to the chassis...
Then I had a look in the box where I store the parts
On the left side, plastic parts already modelled. on the right side, whatever remains to do. If we consider that I have about 6 parts to check for the transmission completion, and for the shocks it is likely the same as on the exceed/midships, we are not far from the end of this chassis modelisation... and the Cosmo Shooter is sharing a lot of those components... This should go relatively quick, especially considering than the wheels are the same as the Midships plus a additional part for the Midships, and the front wheels wiould require some very simple modeling... Time to completion os not that far.
I continued progressing with the remaining part after that picture...
The motor plate is probably the easiest part to measure on this car... And the sketch 100% matches on the real thing (although the picture is difficult to take with only one hand).
The battery holders are in place as well
And last part I did was the receiver plate
Most of the difficult parts are done, now, it should go quick for the remaining elements...
- silvertriple
The advantage with the modular conception of the Nichimos and the fact I model already 3 of them, is that I have already a lot of parts already available...
The rims and tires are the same as the Midships... But there is an additional disk for the Luminous (not a good idea IMHO, I may have a look at what it gives with gold wheels without the disk)... I added the menstion Super Pin Spike on it, which I did not for the Midships...
I did the upper links to complete the suspensions...
All links works perfectly, except on the rear where I could only make them working with a cylindrical movement (probably for less than .1mm)...
Once this was In, I added the axles (same as the Midships) and the wheels...
today, after my day of work, I tackled the last cumbersome part of this chassis (whatever left is super easy ) : the rear cage, which is again a measure nightmare... You have to have all the parts around to set the sitting points right. I first started by the part which is common to the 2WD chassis (I took a copy as new of it, to avoid doing it again)...
Then I completed the parts, and added the brace, body mount and wing mount...
Lastly, I added the switch and resistance holder...
At this stage, the plastic parts of the chassis are done. I need to include :
- the transmission, for which most of the parts (about 95%) are common to the Midships/Exceed
- the shocks (the rear are common to the Midships, and the front are easy to deal with, as there is only 3 parts to modifiy (spring, piston, and body)
And for the bodyshell and wing, I just have the wing, and no bodyshell... I may try to create one just like for the 44B Racing Baja, but that will be very much later. The program for tomorrow is the transmission and shocks, and if everything goes well, on friday I will tear down the Cosmo Shooter to be able to model the 2WD parts...
- 158 Replies
- 8598 Views
Last post by silvertriple
- 87 Replies
- 6134 Views
Last post by Dadio
- 20 Replies
- 5650 Views
Last post by gearhead
- 1895 Views
Last post by mirrorman
- 1252 Views
Last post by caesar
- 20 Replies
- 3583 Views
Last post by BloodClod
- 3104 Views
Last post by Basher67
- 1827 Views
