I need to replace the battery connector on a old timer based nicad charger.
Are there any higher quality, easier to attach Tamiya connectors?
Or is this the best option?
https://www.amainhobbies.com/racers-edge-tamiya-type-connector-plugs-rce2480/p35608
High quality tamiya connectors...Do they exist?
- Has thanked: 1013 times
- Been thanked: 472 times
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: High quality tamiya connectors...Do they exist?
They are just Molex connectors. I buy mine in bulk from Amazon. If you have the correct tools, they are easy to crimp.
I use these dies in my ratchet crimper.
https://www.summitracing.com/parts/tay-43402
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
No.
I have used a few different ones (probably from the same factory) and they are all the same.
- juicedcoupe
None seem any different than any other Molex type connector that I've used. I've used several multi-pin versions in wiring harnesses.
They are a old design and amperage limited. But when used within their design specs, they work fine.
- 20 Replies
- 2751 Views
Last post by jcwrks
- 421 Views
Last post by teman
- 535 Views
Last post by Bimdapogs
- 2137 Views
Last post by shodog
- 1947 Views
Last post by railey72
- 1766 Views
Last post by bearrickster
- 779 Views
Last post by terry.sc
- 1043 Views
Users browsing this forum: Google [Bot] and 7 guests
