Optima Re Re knuckles on a ZX-R?
- Has thanked: 81 times
- Been thanked: 79 times
Starting to think about how i'm going to rebuild the two Lazer ZX-R's and am wondering if these knuckles off the Re Release Optima will fit on a Lazer ZX-R, or if they're sized differently for the Optima Re Re's bushings. Any other Optima Re Re parts, such as the hinge pins?
https://kyoshoamerica.com/ot211.html
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Losi JRX Pro SE
Kyosho Rocky
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Optima Re Re knuckles on a ZX-R?
They are the same dimensions but I believe they swapped the lettering L and R. I’d have to double check but I recall that from when the optima rere came out.
Factory Works website
You don't happen to know if the Optime Re-Re's gear diffs fit. Do you?
I saw I could get a new bumper for a lot less than I paid on Shapeways for a reproduction.
Losi JRX Pro SE
Kyosho Rocky
Losi JRX Pro SE
Kyosho Rocky
No, rere diffs diffs larger outdrive bearings. I want to say it’s a 10x15 where original was 8x14. You can’t get a 10x14 bearing so it’s a no go
At first I thought one of my recently acquired Lazer ZX-R's was a mk2 because it didn't have the funky front-upper rod end, but now I'm thinking a previous owner drilled some holes in the uprights as a mod. Is that what it looks like to anyone else?
Losi JRX Pro SE
Kyosho Rocky
Losi JRX Pro SE
Kyosho Rocky
- Has thanked: 946 times
- Been thanked: 563 times
That looks correct for mk2, so does the front shock tower and chassis with 6 battery slots.
-Brad
Are these caster blocks in any way similar to those of a ZX-s or ZX-5? I actually got a set of drmosfet's ZX-S reproductions out of curiosity when I ordered a couple of other parts I needed.BattleTrak wrote: ↑Wed Jul 13, 2022 8:18 am That looks correct for mk2, so does the front shock tower and chassis with 6 battery slots.
Losi JRX Pro SE
Kyosho Rocky
Losi JRX Pro SE
Kyosho Rocky
- EvolutionRevolution
- Has thanked: 20 times
- Been thanked: 36 times
ZX-5 suspension is very different and the parts really aren't interchangeable with the older cars. The arms are much narrower Also, there are different models for the arms and c-hubs, and they can't be mixed and matched and usually require changing the universals due to length differences.HS-YZ250 wrote: ↑Wed Jul 13, 2022 3:01 pmAre these caster blocks in any way similar to those of a ZX-s or ZX-5? I actually got a set of drmosfet's ZX-S reproductions out of curiosity when I ordered a couple of other parts I needed.BattleTrak wrote: ↑Wed Jul 13, 2022 8:18 am That looks correct for mk2, so does the front shock tower and chassis with 6 battery slots.
At most you could maybe use the rear hubs, but you might need to use different universals because the offset is different compared to Lazer ZX(-R) rear hubs.
- 770 Views
Last post by HKS_TRD
- 265 Views
Last post by XLR8
- 910 Views
Last post by Jay Dub
- 2033 Views
Last post by Welshy40
- 484 Views
Last post by Mr. ED
- 1672 Views
Last post by klavy69
- 995 Views
- 648 Views
Last post by murphy3428
