My 2nd stock Clod
Forum rules
Keep it all things Clod!
My 2nd stock Clod
Hello,
i`m on the way to finish my 2nd stock Clod.
It has a Hobbywing ESC, 2 HPI Firebolt Motors, a Chassisextensionbracket, a Carolina Crusher Body, Aluminium antirotation Brackets, and 2 Servomounts designed by a Tamiyaclub Member.
I have to install some Shocks and have following options:
Cheap 120mm Aluminium Shocks (they are a bit leaky)
Tamiya Agrios 90mm CVAs with extensions (the shocks are super, but i do not like the liftplates. Longer eyelets would be great, but i do not know where i can get some fitting Eyelets.)
120 or 110 mm Inner Spring Shocks from "Mountain" (they lookg great, the people say they do not leak, but maybe they are a bit stiff....) They come in yellow, "gold/orange", black, grey, or red.... I do not know what color would suit the Carolina Crusher.
Also i have to build some Satbilizers for the Crusher
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
- TheDiamondOne
- Has thanked: 1571 times
- Been thanked: 405 times
Re: My 2nd stock Clod
Thanks, i aprechiate it.
I wanted to keep it as Stock as possible.
The hardest Part is to get affordable 110mm oilshocks.
I have Agrios schocks, they are 90mm eye to eye, but i want 110 or 120mm shocks.
Tamiya CVAs are my Favoriten, they Just Work.
Inteenal spring shocks would bei awesome, but theap ones leak, the good ones are to expensive....
- Been thanked: 17 times
Love the old school look! I'm thinking my next clod build will also be an old school truck...
Today i testdrove my Carolina Cruscher the first time.
I really like the Speed with those 2 firebolt Motors and the 7 Cell NiMh Pack.
When i hitted the throttle it felt like i had installed a loose slipper in the Transmission, so i need to attach the tires to the rims anyhow.
I never glued my tires in any of my RCs....
Is there any compund that could be removed at any time?
I know people use rubber Bands, but the Rubberbands that are sold here turn in to a gooie mess or into dust after one year.... Is there a glue that is removable?
I would like that sticky firm rubbery glue that you find in Magazines when they attach some Beautylotion for women or Toys for children (not vice versa ).
PS:
The Truck is pulling hard to the left after about 5 Meters in full throttle. Could this be an effect from unglued tires?
(one side gripping more than the other?)
PS:
Maybe rubber cement? Put it on the rims let it dry then put the tires on.charlie wrote: ↑Sun May 01, 2022 1:22 pm Is there any compund that could be removed at any time?
- Has thanked: 2287 times
- Been thanked: 1994 times
You could try hot glue , I think that's what they use to stick free stuff to magazines.KONG wrote: ↑Sun May 01, 2022 10:55 pmMaybe rubber cement? Put it on the rims let it dry then put the tires on.charlie wrote: ↑Sun May 01, 2022 1:22 pm Is there any compund that could be removed at any time?
I use to work in magazine manufacturing, hot glue was to brital. It's easy to break when stressed. We used a rubbery type of glue to glue on sticker packs. Unfortunately I have no idea what it was since it was like 11 years ago.
I've slways used ca glue. Recently I used some cheap supper glue and noticed it actually broke off, maybe it was because I fidnt rough up the wheel before gluing...
- 690 Views
Last post by minimini
- 2241 Views
- 2064 Views
Last post by stickboy007
- 27 Replies
- 1750 Views
Last post by Timmahhh
- 46 Replies
- 2866 Views
Last post by Tadracket
- 32 Replies
- 2590 Views
Last post by scottmac74
- 2544 Views
Last post by License2iLL
- 902 Views
Last post by victor_cathedral
Users browsing this forum: Brandwatch [Bot] and 8 guests
