Yokomo 870c Build
- caesar
- Has thanked: 170 times
- Been thanked: 163 times
Yokomo 870c Build
Hi All,
I've just received a Yokomo 870c and I'm starting to collect parts for the rebuild.
Does anyone know the size of the ball diffs/thrust balls. I've done a search on here and have come across two answers 3mm and 4mm so not sure which is correct. Also after some diff rings, does anyone have a link to something that will be a direct fit?
Cheers
Cheers
- caesar
Re: Yokomo 870c Build
Thanks mate, found the correct size. 1/8 for the diff balls and 1/16 for the thrust balls. Got a set on ebay, hopefully they turn up quick as I'm itching to get a start on this build.
- caesar
Pic of car as I received it. As you can see it looks like it will clean up real nice. I've found most parts that I need (waiting for them to arrive), all I have left to find is 1 shock clamp and a set of tr8 tyres.
- caesar
I've started to strip this down, not doing anything extraordinary here, I just want to strip, clean, replace any missing or broken parts, rebuild diffs. new body and wheels and that's it.
- caesar
Most of the parts have arrived, so I can now get a start on it. Still haven't sourced any tr-8/tf-8 tires yet but I'll keep looking.
- caesar
Pretty much back together now, diffs rebuilt and are working nicely as far as I can tell. Just waiting on the body and still need to find a set of tires for it.
- TheDiamondOne
- Has thanked: 1571 times
- Been thanked: 405 times
Nice resto! What motor is that??? A Brutus?
- caesar
Thanks. Not sure on the motor, there is a K engraved on the can. I'll open it up at some stage and see if I can tell how many winds it's got.
- TheDiamondOne
If there is a K on the can than its a Killer more than likely. 14 turn.
- caesar
Got my body back from the painter, so all I need now are for my tires to arrive and to find a clean sanyo 1700 SCE saddle pack so I can stick some electronics in it.
- Has thanked: 2287 times
- Been thanked: 1994 times
Looks great , it seems odd not seeing a top deck to the chassis , you just never really see the old backbone chassis used .
- 42 Replies
- 5491 Views
Last post by hondaman
- 1488 Views
Last post by mikea96
- 75 Replies
- 14202 Views
Last post by aip47-2008
- 1431 Views
Last post by flustorm99
- 26 Replies
- 3809 Views
Last post by DerbyDan
- 2063 Views
Last post by Alex B
- 931 Views
Last post by kenooze
- 1898 Views
Last post by Synergy
