Hi guys. Hope this is ok but I thought I would share some of the stuff I created on for my YZ10 rebuild:
https://www.shapeways.com/shops/ernies
Various plastic parts I drafted that might be useful to others. Like if you want to run NiMH batteries that tend to be slightly bigger then NiCD, I have battery posts for them without having to drill new holes in the chassie. Also have the front, center, and rear bulkhead withOUT hood-pin posts since I never used them because the Velcro was always more then enough.
The thing that might be most interesting are the wheels. I recreated the OEM rims but I find it next to impossible to find replacement off-road tires that would fit. So I drafted a version based on the OEM but fit the modern 2.2" tires. Attached is a photo with Pro-Line Resistor F/R.
Hopefully, it will help others...
Ernie
My Shapeways parts for YZ10 Rebuild
Re: My Shapeways parts for YZ10 Rebuild
@mikea96 Thanks, I saw those. I wanted something close to the look of the originals so I figured I would try to recreate, cant quite tell from JC's pics how close they are. Also, I wanted to dress them up a bit with the "Yokomo" engraving (not in the pic above but on Shapeways)...
Ernie
Ernie
- Has thanked: 189 times
- Been thanked: 594 times
Yeah the jc wheels are a little different than the originals as they have a small lip around the outside edge. Your wheels look great!
- 1477 Views
Last post by WriteDean
- 1119 Views
Last post by flustorm99
- 195 Replies
- 17897 Views
Last post by ralphee
- 585 Views
Last post by Dadio
- 975 Views
Last post by GJW
- 26 Replies
- 6607 Views
Last post by Peakey
- 2069 Views
Last post by YZ-10
- 1420 Views
Last post by Cplus
