Cat XLS pivot balls U7150
- slazzaro
- Has thanked: 6 times
- Been thanked: 6 times
Hello! Does anyone know, or can anyone with a Cat XLS re-re take a measurement of these ball studs?
Are the balls 5.8mm diameter?
Thanks in advance! Cheers!
Kyosho Turbo Optima, Optima MID Custom Special, Optima MID Custom Special truck converted
Yokomo YR4 PRO, YZ-870C
Associated TC4, B3 (x2), B4.1 worlds, C4.2, B42, B44, B6.2, B6.2d, B64
Losi XXXT MF2
Tamiya M05
..more in the past, more in the future..
Losi XXXT MF2
Tamiya M05
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
- slazzaro
Re: Cat XLS pivot balls U7150
Thank you! So they're not good for me.. I'll look further for some "vintage looking" 5.8 ball studs to fit my Yokomo 870c. The original ones are so rare!
Losi XXXT MF2
Tamiya M05
Losi XXXT MF2
Tamiya M05
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Are you looking for the ball studs or the links?
I believe that the RPM links for Traxxas vehicles will fit 5.8mm balls. They are made in two lengths and multiple colors.
- Been thanked: 288 times
5.8mm ball studs and open ball-ends are pretty common in vintage Kyosho kits, mainly the Optima series...used for tie rods and camber links, if I'm not mistaken. I believe they're 3mm threaded studs.
- XLR8
Yes, vintage and re-re Kyosho also uses 5.8mm ball connectors and they are 3mm thread.
Also, off-road vehicles from MST uses this size as well. Here are some part numbers to add to your search:
Not sure if any of this is helpful.
EDIT: A Main has the 210491's
- slazzaro
Thank you all! I'm after ball studs. Ideally with inner thread and hex, but I think I'll have to settle for any alternative solution from Kyosho or other makes. After all the ones with external thread do the same job and look similar enough once installed.
Losi XXXT MF2
Tamiya M05
Losi XXXT MF2
Tamiya M05
- juicedcoupe
https://www.amainhobbies.com/kyosho-5.8mm-flanged-hard-ball-3mm-thread-4-kyow0158/p-qqqqqzyqlc2xactz
Just search for "5.8mm pivot balls". You will find some options, not all will be threaded.
- XLR8
As juicedcoupe suggested, I searched Amain's website for "5.8 ball" and found two pages of ball connectors and related products in this size. Besides Kyosho and MST, there are 12 different manufacturers listed that make a 5.8mm ball connector. This can't be mere coincidence, there must be a reason. Why 5.8 I wonder.
- slazzaro
I know! I was also wondering why 5.8?
Losi XXXT MF2
Tamiya M05
Losi XXXT MF2
Tamiya M05
- XLR8
After giving this more thought, I'm guessing 5.8 is the largest ball diameter that can consistently be turned from 6mm diameter bar stock.
What's interesting is that smaller diameters will result in less friction so Schumacher makes 5.5mm and RC10 ball studs are even smaller (although AE uses #4 screw threads which are also slightly smaller than M3).
With M3 as the basis, ball connectors made from 6mm bar yields the greatest range of motion at lowest material cost. Just speculating of course.
- slazzaro
That makes a lot of sense, thank you both!
Losi XXXT MF2
Tamiya M05
Losi XXXT MF2
Tamiya M05
- 1083 Views
Last post by Tadracket
- 1722 Views
Last post by gtrgeo
- 519 Views
Last post by Lowgear
- 3136 Views
Last post by Mad Racer
- 2973 Views
Last post by Eau Rouge
- 4774 Views
Last post by XLR8
- 1097 Views
Last post by Jay Dub
- 1629 Views
Last post by Rich D
