Vintage Nylon Parts Durability
- Has thanked: 55 times
- Been thanked: 92 times
Are nylon parts on the early RC10's durable enough to use for a runner?
Are the later black nylon parts the same composition as the white parts?
I have a 1992 TRX-1. A lot of the original nylon parts had to be replaced as they were very brittle. Would the Associated nylon 66 (?) be the same composition as the Traxxas nylon?
- morrisey0
- Has thanked: 54 times
- Been thanked: 1272 times
Re: Vintage Nylon Parts Durability
Old AE nylon has to be rehydrated as it loses moisture and gets brittle over time. Once hydrated again, it is plenty strong to use on a runner.
- Has thanked: 10 times
- Been thanked: 447 times
Right, boiling the parts for 5-10 minutes works well, or you can throw in a container of room temp water for however long you want.
This applies to associated parts and some Traxxas parts. DO NOT boil yokomo bulkhead caps or Traxxas trans halves.
Throwing in room temp water for longer is safer if you don't know for sure what the part is made of.
- Has thanked: 2287 times
- Been thanked: 1994 times
Looked in depth at this a while ago , warm water is faster 4-6 hours , cold water 24 hours , best not to boil as they may warp , pretty much all nylons are the same in this respect , the thicker the part the longer you soak as it takes time to fully penetrate , only instance where it won't help is if the nylon has started to powder and crumble .
I tried the boiling method on the Traxxas nylon parts. As soon as I showed the buggy a jump the suspension parts just cracked. Thought maybe the Associated nylon could have a different composition?
I'm looking at options for a pre-89 vintage race buggy and don't want to go through the same thing again.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Don't boil them but warmer water is better. And they need time to rehydrate. They have been drying out for 30 years, its going to take more than 5 minutes to undo it.
- Frankentruck
- Has thanked: 1590 times
- Been thanked: 1770 times
When I dye nylon, I get better color transfer above 140 deg F. So warmth does open up the nylon structure to fluid absorption.
Warming the water is best but it's still 4-6 hours , boiling for hours would still be needed and 5min boiling is worthless , the only plastics that require boiling for just minuites are the PB Mini Mustang / Maxima arms and it's not for hydration but to de-stress the plastic, it's probably where the idea of boiling comes from.
I bought this. I'll strip it and soak the nylon parts in warm water for a couple of days. Hopefully it's all good. My second RC10, sold the last one in 1993. Using it for racing.
- Regular Member
- Has thanked: 5 times
I just got a new to me Cadillac A stamp and plan to do a runner as well. After reading this post, I planned on soaking the suspension and mounting parts to rehydrate them. Should I also do the gear box and rear bulkhead pieces too?
This place is an amazing resource.
Thanks in advance,
Pete
Thanks in advance,
Pete
Yes I'd do all of it , only takes a day and it costs nothing . If it's got screws in it or under any load it's worth it .
- 994 Views
Last post by Mark Westerfield
- 1185 Views
Last post by kaiser
- 541 Views
- 1001 Views
Last post by badhoopty
- 667 Views
Last post by littleVETTE
- 1460 Views
Last post by blubblood
- 41 Replies
- 5257 Views
Last post by REMJ666
- 646 Views
Last post by Der Kommissar
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot], Tbot [Bot] and 26 guests
