B3 Top Shaft ID
- Has thanked: 37 times
- Been thanked: 17 times
B3 Top Shaft ID
Can anyone ID this top shaft in the B3 I'm building? It's aluminum, and there's a stud that threads in for the slipper hardware. I can't seem to find anything online. Thanks in advance.
- Has thanked: 750 times
- Been thanked: 26 times
Re: B3 Top Shaft ID
Hi,
Looks like this shaft,
https://www.customworksrc.com/product/top-shaft-for-2-4-gbx/
For these slipper eliminators,
https://www.customworksrc.com/product/dominator-gear-hub/
https://www.customworksrc.com/product/slipper-eliminator-for-2-4-trans/
Re: B3 Top Shaft ID
It does, but that's strange because it still has the factory slipper setup. I suppose someone could've eliminated the slipper, tore up the gearbox, and decided to go back to stock.DaveM wrote: ↑Sun Aug 01, 2021 2:51 am Hi,
Re: B3 Top Shaft ID
Hi,
Pictures would be good.
I missed the part about the stud, it could be a Factory Works Slipper,
http://www.factoryworks.com/
Scroll down the L/H side to power clutch.
- Has thanked: 822 times
- Been thanked: 2418 times
Re: B3 Top Shaft ID
That is how our Power Clutch are designed but it’s not ours, we didn’t make one for stealth trans
Factory Works website
Re: B3 Top Shaft ID
I'll take some pics in a bit. I haven't cracked the case all the way open yet.DaveM wrote: ↑Sun Aug 01, 2021 6:37 pm Hi,
Re: B3 Top Shaft ID
Hi,
Looks like you have a mixture of parts mostly B3, perhaps download a manual?
https://www.associatedelectrics.com/teamassociated/cars_and_trucks/RC10B3/Team/manuals_setups/
Maybe get a Team Associated top shaft ASC6571 ?
Re: B3 Top Shaft ID
Yeah, I've got the manual.
I don't know if I need to change it. It was assembled when I got it, so I'm just going to slap it back together. I was curious if anybody knew what that top shaft was, and if I possibly needed different spacers to shim it inside the case or whatnot. There was 2 diff gears, one white, one gray, and 2 idlers, one black and one grey, and the white diff feels chunky in the transmission, like the mesh is off, so I mixed and matched until the transmission felt smooth.
These are the joys of buying used cars, I suppose.
Thanks for your help!
- 1316 Views
Last post by 68sportcoup
- 1718 Views
Last post by Chillout47
- 893 Views
Last post by ljh501
- 860 Views
Last post by JosephS
- 151 Views
Last post by Frankentruck
- 1563 Views
- 737 Views
Last post by askbob
- 2566 Views
Last post by adam lancia
Users browsing this forum: Ahrefs [Bot], DotNetDotCom.org [Bot], Facebook [Bot], Google Adsense [Bot] and 29 guests
