Traxxas Bullet Diff
- Has thanked: 4 times
- Been thanked: 4 times
Traxxas Bullet Diff
So, I am trying to get my old decrepit Bullet running again and have been assembling some parts from ebay. It appears I hit a problem with the diff. My original diff had the bevel gears and had seen better days. I was going to buy the planetary diff when a 4620 ball diff popped up on eBay for what seemed to be a reasonable price. I received the diff and it appeared to have all of the parts even though the package had been opened. The instruction sheet was missing but I was not too concerned as it is not the first ball diff I have assembled. I assembled the diff using associated stealth lube on the balls and the black grease on the thrust bearing. Other than the balls being extremely tight into the gear it went together without issue and feels smooth. When I went to install the diff in the gearbox along with the required 1783 top gear I found the diff was too small. Did I receive the wrong diff or does this diff normally have a larger gear?
George
Thanks,George
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Traxxas Bullet Diff
Here is the parts list and a pic from the eagle manual since it came with the ball diff. Maybe this will help
Sorry the pics are sideways. I don’t know of a way to fix it on here
Factory Works website
Thanks! So it looks like I need a 4624 gear. I found a listing for one on Amazon which indicates the gear has 68 teeth. The gear I currently have has 60 teeth. I assume this was for the Rad2 and the like which had an idler gear if I remember correctly. Is it possible that the rest of the diff is correct and I will only need the gear?
- Has thanked: 10 times
- Been thanked: 447 times
It looks that way to me from the pictures. There is a larger gap between the teeth and outer part of the diff ring, which looks like the ring is the same
Thanks everyone for the help. I was able to get a copy of the instruction manual from Traxxas and it showed the 4624 gear was needed for a Sledgehammer which uses the same gearbox as the Bullet. Thankfully they seem to be readily available.
I posted the instructions here in case anyone runs across this needing a copy. https://www.rc10talk.com/viewtopic.php?p=524820#p524820
Thanks,
George
Thanks,
George
Hi
Someone know where i can buy a new/used radicator gear halves ( 1681) in white?. I need for a restore.
Thanks
Thanks
Those are the toughest Traxxas parts to hunt down since almost all of them broke. Good luck in your search!!!
If you not totally in love with a full restore, and don't mind drilling holes, you could update the trans and separate arm mounts style used is other models. Like hawk 2, rad 2 etc
Actually, some of the later models may have incorporated the arm mounts again
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
besides what jwscab already mentioned...Ebay. Just seen some that were in used parts lot when I searched Vintage Traxxas over the week.
- 826 Views
Last post by purpletimbo
- 1384 Views
Last post by DACECOLI
- 2519 Views
Last post by KingZulu
- 1711 Views
Last post by civilguy
- 1340 Views
Last post by mikenice
- 1440 Views
Last post by Rinzler
- 2412 Views
Last post by Lonestar
- 26 Replies
- 478 Views
Last post by morrisey0
