Hey guys. Took apart the transmission of my 10t to clean it up, assess the condition, and throw in some new bearings... in the process, I noticed my diff thrust spring (that goes in the drive shaft) is missing. I have one on order, but I’m wondering if it’s the same as the spring on the assembly that holds the big main spur gear on?
I just hate to sit around and wait for another week to get this tranny back together.
Diff spring vs clutch spring
- Regular Member
- Has thanked: 6 times
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: Diff spring vs clutch spring
No, not the same.
It was probably a good idea to replace the thrust spring anyways. If they loose tension, it can cause the diff to run loose and damage it.
- Regular Member
Damn. Well, thank you. Guess we’re back on hold. This is my last step major step before firing the thing up for the first time in 25 yrs. So close!juicedcoupe wrote: ↑Wed Feb 03, 2021 4:20 pm No, not the same.
- 362 Views
- 663 Views
Last post by MONSTER
- 715 Views
Last post by teman
- 234 Views
Last post by JosephS
- 37 Replies
- 2937 Views
- 351 Views
Last post by tulsa
- 35 Replies
- 1783 Views
Last post by 17nut
- 1167 Views
Last post by Steve71
