Turbo Optima Mid SE Front Hub Question.
- Has thanked: 78 times
- Been thanked: 21 times
So my new Optima has what looks like aluminum front hubs......and plastic rear. Is that standard? Or are the front after market? Just curious.
Thanks for all the help.
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
Re: Turbo Optima Mid SE Front Hub Question.
Interestingly, diecast aluminum was used by Kyosho for the standard kit front hubs.
This is true for the re-released versions as well.
- Has thanked: 60 times
- Been thanked: 83 times
Added strength for steering knuckles? My GV Beagle Optima clone is the same.
Thanks for the info guys. 2nd question. This is my first Optima I've ever messed around with. The body that came with it, seems to be too short for the chassis? Am I an idiot (distinct possibility ) ? Or does that back hole in the body not go to the rear shock tower?
Wrong body for the car?
- XLR8
Your car appears to be original wheel base so that body should fit.
When installing the body, I've found that it's best to fit the front between the shocks and drop it into place first then the back will simply drop over the rear body mounting.
You're clearly not an idiot since you bought an Optima Mid.
Thanks for the vote of confidenceXLR8 wrote: ↑Sat Jan 02, 2021 11:18 am Your car appears to be original wheel base so that body should fit.
When I put the body on the front body mount the rear is 1/2" or so short of reaching the rear body mount. I'll take a picture when I get a chance. I can get one or the other. Not both. Is it supposed to reach both?
- Paolino70
- Regular Member
- Has thanked: 26 times
- Been thanked: 11 times
I would be curious to see a photo from above without bodywork and a photo of the chassis taken from below ....
I spent a lot of money on women, car, motorcycles, alcohol, and rc model ..... the rest I am quietly squandering ...
- Paolino70
- Regular Member
what happened to the upper frame?
- Attachments
- PXL_20201231_223352503.jpg (76.53 KiB) Viewed 1633 times
- Been thanked: 288 times
It looks like the previous owner incorrectly installed the rear shock tower to the back of the rear bulkhead instead of the front. Put it on correctly and your body should fit again. Here's a modded but correct assembly for comparison:
- 4200 Views
Last post by rccars4sal
- 68 Replies
- 18825 Views
Last post by Garage Hack
- 52 Replies
- 10441 Views
Last post by HKS_TRD
- 19 Replies
- 6387 Views
Last post by lin6499
- 2003 Views
Last post by Bo Wallen
- 1149 Views
- 2369 Views
Last post by RC10CE75
- 1071 Views
Last post by GJW
Users browsing this forum: No registered users and 17 guests
