DSPPC EXP3 MID kit Cougar
Moderator: Djerk
- Djerk
- Business Member
- Has thanked: 34 times
- Been thanked: 69 times
Right... this is going to be my first topic here!
As you see in the topics name.. you all probably see where this will go to.
This project started somewhere in September 2020.
A friend, (Marshky) helped me with the CAD designs, and others supported me with with all the options and advices i needed to complete this job.
As for now, i am finishing on the details, waiting to get new parts coming in, and measuring al lot with the Caliper (a lot!! Haha).
I the end, the idea is to create a full kit, to build your own Cougar MID car! A full kit with all carbon/plastics/screws/bearings what you’ll need. You only need to use the Cougar transmission and suspension parts!
It won’t be cheap, but if there is enough interest.. it will get less expensive.
So, you all have to wait some time before the first pictures show up here.. but, they are coming... (end of January!?) !
Any questions, just let me know.. regards Dirk.
- Djerk
- Business Member
Re: DSPPC EXP3 MID kit Cougar
First part build.
Using the Pro Trans, pinion 23 and spur 89
Motor will be the Hobbywing V10 8.5T
Hard anodized the side plates in plain matt finish.
- Djerk
- Business Member
Putting the front end together.
New designed ballrace steering system.
8 bearings inside, original steering posts, carbon Ackerman.
- Djerk
- Business Member
Building the rear end.
Created an easy way to adjust toe inn-out and Antisquad.
Using all original Schumacher parts for suspension.
- Djerk
- Business Member
Getting the transmission on, building the rear shock tower and placed them on the chassis.
(Rear tower will be adjusted, needs a new design).
- Incredible_Serious
- Has thanked: 1405 times
- Been thanked: 861 times
Watching with interest.... certainly looks like great workmanship so far....
- Djerk
- Business Member
Added most of the NIB suspension parts.
Still need to tweak some things, but close-as for now.
Also you have a sneak preview of the paintsceme on the nosecone...
(Rear shock tower did not arrived today with post.. #waitingforparts)
- Djerk
- Business Member
Just a minor little detail on the Sunday afternoon...
My friend Marshky came up with an idea when CAD designing the front end (which other brands do..).
Put some holes in the Ackerman, and brace, make a reference hole in the tower... so you can easily set up the middlepoint of the steering.
Smart, easy, simple!
- Djerk
- Business Member
Some tiny updates in between today.
Mounted the waterfall motor guard. This was was needed to stabilize the motorplate. And just looks really nice!
Also mounted the battery straps.
And put the servo in place (the most thight-spot-on-fit ever!)
- Djerk
- Business Member
Rebuild the Vari-shocks.
The shocks have been re-anodized, so that all aluminum parts on the build have the same color.
Used the Muzzoom Models Motorsport teflon pistons (2 holes).
All new seals, and new shock shafts.
Went for the bigbore springs on this one, and they look pretty cool i must say!
- Djerk
- Business Member
Right... this is something i always wanted back in the day...
Double bearings in the front hubs!!
I used all standard Schumacher parts for this piece of long thinking-engineering... haha.
Not sure how it will work when racing, but i like the feel how it came out.
10mm alloy castle axles
2 bearings
Squeezed a 3mm o-ring in the wheels
Milled a stainless axle shaft to fit the 10mm caste axles
Used a washer to get rid of the play
In the end, it feels very solid, and no play left.
When testing we will see how it works! Haha.
2 bearings
- Djerk
- Business Member
Today finally the postman arrived with the new designed rear shocktower!
So, mounted it, and finished almost the whole rear end.
Together with the carbon milled washer plate, the whole rear bulkhead, and carbon shock tower is realy solid. Pretty happy about how it came out, plus the way it looks.
The Schumacher wingmounts are positioned as low as possible, to create a really streamlined appearance.
Fitted the rear shocks, and all fits nicely!
What do you all think?
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
That thing would compete with anything made today! F
- 3856 Views
Last post by Retro rc
- 544 Views
Last post by Djerk
- 25 Replies
- 5952 Views
Last post by eugine
- 1122 Views
Last post by JK Racing
- 1591 Views
Last post by KidAgain
- 333 Views
Last post by 76jimmy
- 173 Replies
- 25301 Views
Last post by isaacn
- 1486 Views
