TAG Pro 10
- 1300GT
- Has thanked: 331 times
- Been thanked: 272 times
TAG Pro 10
I scored a couple of very well used Pro 10s nearly two years ago. They'd been converted to nitro, consequently, both the motor mounts were hacked. A lot of the parts are re-useable. I have a few new parts to add to the mix as well.
This will be a shelfer as I have an SG Coyote that I will run. Plus parts for these are like hen's teeth.
This is a link to Dinglem's Coyote build.https://www.rc10talk.com/viewtopic.php?f=33&t=41313
In it is a lot of info about the Coyote and it's transition into the Pro 10.
First up, the diffs. Before and after shots here. Note the steel gears. Both diffs are now chock full of Tamiya's AW grease.
Chris.
Toys.............they are!
- dinglem
- Has thanked: 243 times
- Been thanked: 629 times
Re: TAG Pro 10
I will be looking forward to updates to this thread.... (am still waiting to hear back from my Italian model shop guy regarding the motor mount...)
- 1300GT
Re: TAG Pro 10
Thanks Martin, hopefully he still has it.
The diffs in their housings. Note the motor mount has been hacked. Thankfully, the bearing housing was untouched. I'll continue with the build and replace the mount when I can. All the driveline bearings have been cleaned out and re-used.
Chris.
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: TAG Pro 10
Looking at the stripped down diff photo it looks like yet another slight difference in design , the out drives and sun gears are splined together not like the older versions where they were key'd together .
- 1300GT
Re: TAG Pro 10
Absolutely correct, the Pro 10 output shafts are splined while the Coyote has two flats to mate with the sun gears. I haven't included the info in the other thread as I don't know if any Coyotes ever used them. At a guess, once TAG started modifying the chassis they were most likely part of the upgrade.
New chassis rails fitted with upper suspension arm mounts and new steering bellcranks.
Chris.
- 1300GT
Re: TAG Pro 10
New bulkheads, chassis spacers/servo mounts fitted plus the diff housings. The shock towers are from Factory Works and are top notch. I have the originals but they are well past their use by date. The drive shaft linking the front and rear diffs isn't fitted yet.
Chris.
- 1300GT
Re: TAG Pro 10
I gave the shocks a thorough going over with sandpaper and metal polish after de-anodising them. The rears had suffered from years of spring gouging and really needed it. They're not perfect but they look great compared to what they used to look like. Note the brass spring collars. Pretty nifty.
Chris.
- 1300GT
Re: TAG Pro 10
I couldn't help myself, I had to start reassembling the car. The upper and lower suspension arms as well as the bearing carriers are used. The best bits were spiffed up and refitted. Particular attention has to be paid to the suspension pivot balls. All were spun on an M3 screw in a Dremel and polished up. Some had to be sanded first. TAG's machining in this area is a bit lax. There was a difference of up to 0.12mm in diameter between the smallest and largest balls. This is the difference between smooth arm movement or sticking.
Chris.
- 1300GT
Re: TAG Pro 10
Shocks rebuilt and reinstalled. Just a bit of AE's Green Slime on the O rings and a couple of drops of oil in each shock. Enough to dampen the bumpiest shelf.
Chris.
Re: TAG Pro 10
Looking very nice , what are the additional mount holes in the knuckles for , looks like they could be used with a C hub at the rear maybe ?
- 1300GT
Re: TAG Pro 10
Thank you Sir.
They can't be used on this buggy. I thought at first that it might be possible to utilise them for additional castor at either end but it drops the steering ball end too far down for steering duties and increases bump steer dramatically.
I don't know if TAG pilfered them from another model or they were specifically made for the Pro 10. I do know that the model after this one the "Jet" doesn't use them.
Chris.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Re: TAG Pro 10
Ahem..... I thought you didn't have shelfers
- 1300GT
Re: TAG Pro 10
I do have one shelfer, this'll make two. Plus I do have a single NIB.
Chris.
Re: TAG Pro 10
Maybe the outer one is for a steering limiter pin ? It does look like you could rotate it 90°axially and there would be a pin mount for a bottom arm and the holes for the steering arm would mount a ball for the top arm , a bit like the yokomo 870c had double duty knuckles.1300GT wrote: ↑Mon Jan 11, 2021 5:35 am Thank you Sir.
- Been thanked: 288 times
Re: TAG Pro 10
Sweet...I do love me some fine-polished shocks!1300GT wrote: ↑Sat Jan 09, 2021 12:36 am I gave the shocks a thorough going over with sandpaper and metal polish after de-anodising them. The rears had suffered from years of spring gouging and really needed it. They're not perfect but they look great compared to what they used to look like. Note the brass spring collars. Pretty nifty.
- 128 Views
Last post by 1300GT
- 142 Replies
- 22213 Views
Last post by micb1
- 821 Views
Last post by Lowgear
- 60 Replies
- 7079 Views
Last post by coxbros1
- 551 Views
Last post by 1300GT
- 1867 Views
Last post by Mr. ED
- 37 Replies
- 1481 Views
Last post by 1300GT
- 731 Views
Last post by BattleTrak
