2.2 Wheels for Ultima Pro
- Regular Member
I know I’m 20 years behind, but I am struggling on finding wheels to update my Kyosho Pro. I would like to keep the original chassis and axles, are there any 1 for 1 replacements for the 1.9 wheels so I can run UM754 and Um755’s?
- Has thanked: 822 times
- Been thanked: 2418 times
Re: 2.2 Wheels for Ultima Pro
Turbo scorpion wheels would probably be the easiest matching set to run. SCH006 rears and SCH005 fronts. These are 2.2 and the offset should be correct. These turbo wheels use a 12mm drive, where the standard scorpion wheels use a serrated washer so stay away from them.
https://www.kyoshoamerica.com/22-Rear-Wheel-2pWhiteScorp_p_24131.html
https://www.kyoshoamerica.com/22-Front-Wheel-2pWhiteScor_p_24128.html
Factory Works website
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
Jeff's right. Not only are those wheels a direct fit, but I think they look great on an Ultima Pro.
The style seems to go well with those angular body lines and graphics.
- cas22
- Has thanked: 31 times
- Been thanked: 106 times
Hi
May be some use, i found the "pepper pot" style kyosho reproduction wheels in the UK
https://www.jcracingproducts.co.uk/kyosho-optima
They look the same pattern as 1.9" wheels of the era, but accomodate the 2.2" tyres available now.
Got some for my rocky and laser projects,
Good luck.
Good luck.
- 2544 Views
Last post by RichieRich
- 696 Views
Last post by Mr. ED
- 21 Replies
- 4437 Views
Last post by sundevil67
- 1805 Views
Last post by Synergy
- 832 Views
Last post by keithrc
- 1867 Views
Last post by Delorean
- 66 Replies
- 9347 Views
- 686 Views
Last post by GJW
