What's everyone doing for ball studs?
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
JConcepts, Custom Works, AE - everywhere I look, they are either discontinued or out of stock. I'm looking for the original size (I think it's .17" diameter ball) with #4-40 threads and at a sensible price. I'd have better luck finding M3 but I want 4-40 since they are going into vintage parts - which are also discontinued and becoming more scarce by the day.
If they are no longer available then I guess I could source some 3/16" hex bar, grind a form tool for lathe and attempt to make them myself. I already have 4-40 dies.
Any advice?
thanks
Any advice?
thanks
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: What's everyone doing for ball studs?
Lunsford is still showing them, 4.3mm x 4-40.
Last ones I bought were HPI but were m3.
Occasionally, I see bags of used ones on Ebay.
Also, check CRC. They show 4-40 versions but don't list the ball size.
The Dubro 4-40 is huge.
- radioactivity
- Has thanked: 345 times
- Been thanked: 516 times
Schumacher pro ball studs, best I remember, will work. They are the broached style though.
Custom Works Hex Drive Ball Studs look like a possible candidate though Amain is out.
Chuck
Chuck
- XLR8
Thanks for the advice. Here's an update:
Custom Works:
Actually, CW does have ball studs in stock but they are the "short" version (8121). The price is $8.00 for 6 studs. These will work for steering but the camber links will require the longer version (8122) which are out of stock. From the photos, these appear to be broached and they also have a hex body.
Lunsford:
These are the correct size all around, they are broached only (not a problem) and they cost $68.99 for a set of 16. This is really not in the budget at this time.
Schumacher:
These have a 4.3mm ball and are longer than the CW's but they have M3 threads (U4274). They cost $4.89 for 4 studs. I'd rather not use M3 with vintage nylon parts since the larger threads could permanently oversize the hole making them unusable with #4-40 hardware in a future build. Since RC10 nylon parts are discontinued and it appears they will never be made again, I really want to preserve these parts - especially those that are currently original and unmodified.
CRC:
These are #4-40 and I believe the ball size is 4.3mm and they are anodized so I reckon they are aluminum - I've requested confirmation. The cost is $5.99 for 4 studs. I won't use aluminum ball studs with an off-road car but these could be used as place-holders or for a shelf car (after removing the red anno).
I am pulling together an order for various bar stock materials from McMaster and I will add a length of 3/16 steel hex rod to try-out on the lathe. The price is $5.49 for 3 ft. I hope this works but I'll post an update. Do we know if the original AE ball studs were heat treated or if this is even necessary since they are going into nylon? Maybe they were heat treated to reduce wear??
thanks for commenting.
Custom Works:
Lunsford:
Schumacher:
CRC:
- Has thanked: 10 times
- Been thanked: 447 times
They are probably gone by now but I bought a bunch of the titanium nitride associated balls that are broached for a hex on top. I guess they were for the touring cars? But they will have to do for new builds.
Another option is from dubro for steel balls. Last time I checked.
I'm not sure if the stock ones are hardened. I don't think so.
- XLR8
Thank you Joe. I didn't think to look at touring cars.
So I just checked AE and apparently the TC4 was the last touring car to use imperial units hardware - the TC5 and later cars use metric. It looks like the TC4 ball studs fit the 6274 ball cup (4.3mm ball), are #4-40, are broached and unfortunately have been discontinued. Here are those part numbers: 3981,3983, 6277. There is a pack of 4 p/n 3981 on the bay from the UK with shipping set at $32.86. There a few of the other p/n's also listed but the cost is prohibitive.
Meanwhile, I just received this email from CRC regarding their 1409 ball studs.
Hi Doug,
The ball diameter is 4.32-4.34mm.
These have 4/40 threads, and the threads are about 7.1mm.
Yes, these are made of aluminum.
Thank you,
Brian Wynn
Team CRC
If these were steel, they would be perfect.
Hi Doug,
Thank you,
Brian Wynn
Team CRC
- KidAgain
- Has thanked: 288 times
- Been thanked: 198 times
So you're looking for steel ball studs, give me a count of what you need for the build if you are okay with used but not destroyed ball studs I have a bunch of take offs from when I went aluminum........... they will just need a cleaning.
Also are they black or shiny with hex no hex?
Jake
Jake
Gone: RC10, Jrx-2 and Jrx-t
Current: 3 SC10 first gens, 3 SC10 Street Outlaw's, 12 RC10 DS’s, Carbon RC10T, RC10LSS,RC10L, RC10 Graphite,RC10 B44
- XLR8
Thanks Jake.KidAgain wrote: ↑Fri Oct 30, 2020 9:18 am So you're looking for steel ball studs, give me a count of what you need for the build if you are okay with used but not destroyed ball studs I have a bunch of take offs from when I went aluminum........... they will just need a cleaning.
Jake
For the current build, at the very least I'll need 6 shorts and 6 longs.
I've just received an email from CW and they expect to have their long ball studs available again next week so I'll go ahead and order a couple packs of each and this will provide a few extras for future builds.
However, if the plan falls through, I will reach out to you regarding your take-offs. Thanks again!
- KidAgain
Ill pull out my best short and long sets and post a photo in the next couple of days bud.XLR8 wrote: ↑Sun Nov 01, 2020 3:04 pmThanks Jake.KidAgain wrote: ↑Fri Oct 30, 2020 9:18 am So you're looking for steel ball studs, give me a count of what you need for the build if you are okay with used but not destroyed ball studs I have a bunch of take offs from when I went aluminum........... they will just need a cleaning.
Jake
- XLR8
It's taken some time but those standard length ball studs (p/n 8122) are back in stock at Custom Works.
https://www.customworksrc.com/product/hex-drive-ball-studs/
- 1194 Views
Last post by DrumAnBass
- 1092 Views
Last post by slow_jun
- 579 Views
Last post by jkelm24
- 912 Views
Last post by jkranz
- 938 Views
Last post by lmw94002
- 1615 Views
Last post by KidAgain
- 666 Views
Last post by juicedcoupe
- 658 Views
Users browsing this forum: carloco8 and 33 guests
