Triumph front hubs
Post Reply
al.48
Triumph front hubs
Post by al.48 »
HELP !! Anyone built tmw-1 ? Triumph front hubs, silly question I know ! Thought I'd start rebuild by rebuilding front end .easy you all shout ! OK, the wheel shaft is smaller in diameter than the hole in the steering arm !
Ie shaft is 6mm hole is 8 . And the hole for the king pin in the hub is larger than the king pin, so its like a dick in a bucket ! Anyone else come across this? Cheers
al.48
Re: Triumph front hubs
Post by al.48 »
Sorted !! Just got to find the rest of the parts now ! More later. Cheers all
Mr. ED
Has thanked: 58 times
Been thanked: 56 times
Post by Mr. ED »
Looking good so far. Which wheels do you use?
al.48
Post by al.48 »
They are jc rc10 with rc10 front axles
al.48
Post by al.48 »
anyone got any ideas for a battery mount ? Something that looks retro
Mr. ED
Post by Mr. ED »
Depends on the format of pack you want to install. Generally I don't buy battery holders for my cars but make something myself with left over parts or plain stock like spacers and scrap gf10
Mr. ED
Post by Mr. ED »
2 bodyposts, 2 clips, cut-down plastic T-strap and a piece of foam. The esc and receiver on either side stop the pack from rotating.
al.48
Post by al.48 »
8) Think I've got all bits sorted , bar one ! A wing mounting. Any ideas ?
mcdze
Been thanked: 23 times
Post by mcdze »
wing mounts - if you cant locate the triumph ones you could try to see if XXX buggy mounts are available .. they will place the mounting stud close to the same place on the wing but the tower mounting holes are spaced closer so you would have to drill 'one hole' each side to screw them on .. the conical-shaped wing mount top washers are an overlooked item to, if you dont have those i'd try to pick up a pair also ..
al.48
Post by al.48 »
Post Reply
  • Andy's front C hubs
    by Matt Mason » » in Yokomo Forum
    Last post by Matt Mason
  • Front C hubs for 870c build- zc-413
    by Splat! » » in Yokomo Forum
    Last post by Ronbo
  • Hotshot front wheel slipper hubs
    by dinglem » » in Tamiya Forum
    Last post by dinglem
  • Rear Hubs
    by rfulcher » » in RC10 Buggy Forum
    Last post by juicedcoupe
  • rear hubs??
    by chophead69 » » in Temple's RC10 Tech Forum
    Last post by chophead69
  • 12 scale hubs
    by minreg » » in Associated On-Road Forum
  • Triumph
    by Momo5 » » in Kyosho Forum
    Last post by highwayracer
  • The Triumph of Mr. ED
    by Mr. ED » » in Kyosho Forum
    Last post by Mr. ED
Return to “Kyosho Forum”
Users browsing this forum: No registered users and 24 guests
