Removing Paint with Fuel Problem
I have an old T3 Body I want to repaint for my 7 yo Son (fav color = Green and Orange). It is presently painted Candy Purple (just the Candy part, no Backing color) with a Florescent Yellow Stripe. I decided to spot test the Fuel Removal Method the other night. So, I took a clean rag and put a little fuel on it and started rubbing the yellow first. It came RIGHT OFF. I thought, "GREAT"!!. Then I started rubbing on the Candy...and I rubbed...and rubbed...and you get the point. It had NO effect on the Candy. I resoaked the rag several times and still didnt notice any removal. Anyone else tried removing Candy Paints with Fuel?
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: Removing Paint with Fuel Problem
sounds like the Candy paint does a killer job of etching into the plastic. You might be SOL
- Brandon G
Try laquer thinner.
that is what is used to thin the pactra lexan paints anyway. seems to cut the tough stuff pretty good.
- Erich Reichert
Ya it may be a thing that the yellow paint was acrylic (waterbased) so it came off without a fight and the candy might be enamel paint which needs a stronger solvent to remove. Just curious, you can still buy T3 bodies, why go through all the time and trouble?
First, and foremost, Im Cheap!!! I also like doing things the hard way, and its just laying around here taking up space, but its in really good shape, I'll just have to do new body posts.
Laquer Thinner wont mess up the body?
- Erich Reichert
LOL I hear ya! I don't konw about thinner. Testors make a "Brush Cleaner" that i've always used to take off paint like that. You wipe it on with a rag and let it sit a bit then pretty much wipe it off with the paint.
- shodog
Lacquer thinner will probably destroy that body. I wouldn't try it.
- Brandon G
Cant hurt it too badly, as this is what you use to thin the Pactra lexan paint for airbrushing?
I would not let it pool up and sit, it may affect the lexan?
I let some nitro fuel pool up and it left foggy areas in the lexan. And no it wasn't where the paint etched into it, it was in an unpainted portion of the window, which is now ruined I might add. Unless I cut the windows out of course....
- Regular Member
try greased lighting (degreaser cleaner) full strength, soak in a container overnight, i have good luck with it, but some paints it did not work on but works on most, also brake fluid seems to take off the paints greased lighting did not, both safe on lexan
anyone ever try aircraft stripper? it comes in a spray can at auto parts stores. i know what it does to a real car
do not use aircraft stripper. i use it to strip diecast cars for custom builds and it MELTS any and all plastic.ericsp2 wrote:anyone ever try aircraft stripper? it comes in a spray can at auto parts stores. i know what it does to a real car
I was stripping a body shell that had numerous paints on it, some came off with nirto fuel while others didnt. My girlfirend was removing some nail varnish with, you guessed it nail varnish remover. I tried this on the body shell and it worked suprisingly well. Try a dab of that if theres any lying around.
- YZ-10
i agree with the testors stuff, have heard of excellent results from it, sadly it can't be shipped airmail and i haven't managed to get hold of any myself in uk yet, i have a shell waiting as wellErich Reichert wrote:LOL I hear ya! I don't konw about thinner. Testors make a "Brush Cleaner" that i've always used to take off paint like that. You wipe it on with a rag and let it sit a bit then pretty much wipe it off with the paint.
hey yz10 i can put some in a can of coffee for you and send it. let me know
- 2949 Views
Last post by mattxb
- 1830 Views
Last post by Winger
- 1728 Views
Last post by R6cowboy
- 512 Views
Last post by templeofspeed
- 1980 Views
Last post by Winger
- 22 Replies
- 3114 Views
Last post by Lowgear
- 647 Views
Last post by Der Kommissar
- 930 Views
Last post by LowClassCC
Users browsing this forum: Majestic-12 [Bot] and 12 guests
