Kyosho Icarus restoration and video
- Regular Member
- Been thanked: 7 times
The Kyosho Icarus is a 2WD entry-level RC car from the year 1985/1986. It has the same chassis as the Pegasus, Cosmo and Cox Bandido. The original motor is the 360ST, size 550, 22 turns - 22,000 rpm and it has independent suspension on four wheels with oil dampers. This buggy is the version that Graupner distributed in Germany.
I bought it disassembled and there were parts that were not from this car:
I have the original rims and the new front tires; I don't have the rear tires. There were other front rims and rear rims on the Tamiya Hornet. The chassis was strongly marked by scratches on the bottom but no broken parts. The shock absorbers were new as if they had changed.
The most important thing was to have all the transmission parts because they are expensive, hard to find and there are no alternatives.
I disassemble the gearbox because there is a strange noise.
The gearbox is fine and had a loose bushing. It is cleaned and oiled. The motor pinion has 18 teeth and a 0.8M module. The gearbox has a ratio 18/52 * 18/52 ---> 8.35: 1
The wheel axle is worn in the rolling area. This also occurs in the Cosmo and the Pegasus. TThe previous owner did not do the maintenance and there was no grease in the bushings.
It is better to use 10x6 mm flanged ball bearings
A new wheel axle is quite expensive and difficult to obtain; I placed a needle roller bearing 10x6 mm and 10 mm wide.
The transmission parts have strange measures and shapes and are not compatible with other spare parts:
The LeMans 360ST motor has interchangeable brushes but cannot be opened. I put the very fine sandpaper in a screwdriver and put it in the hole of the brushes to polish the collector. I use a drill to turn the rotor.
Video:
Complete transmission test and measure the motor speed (sound level meter):
The chassis is clean and the transmission mounted. The battery is placed by opening a cover under the car
The double wishbone front suspension is made up of flexible plastic arms: there is no axle.
Suspension clearance is repaired with an o-ring.
I made two polyethylene holders for the servo. I did not have the original holders.
I have new chrome rims and a rear wheel adapter; I also have new front tires.
I mount 4x8x3 bearings in the front wheels.
The rear rims are 1.55" size and I can choose between the Tamiya Hornet or Marui tires that I have.
I paint the white letters on the tires. I also mounted the ESC and the receiver in the car.
The Icarus buggy looks like this:
In action (video):
Translated from:
https://reparar-cochesrc.blogspot.com/2020/03/restauracion-reparacion-de-kyosho-icarus.html
(sorry for the translation errors)
https://classicrccars.wordpress.com/2021/01/15/kyosho-icarus-restoration/
Video:
In action (video):
Translated from:
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
- TheDiamondOne
- Has thanked: 1571 times
- Been thanked: 405 times
Re: Kyosho Icarus restoration and video
I too really dig this nice blast from the past. Great build thread!
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
I agree, very nice restoration work. The car goes very well.
I'm completely unfamiliar with this car: it seems very Tamiya like.
It also appears that the front steering uprights are the wrong way around - but I guess that's how they were meant to go.
Wouldn't it be interesting to speak to the car's designer?
By the way, your translations are spot on. Good job!
- Has thanked: 822 times
- Been thanked: 2418 times
If you haven’t seen a Pegasus or Icarus up close you are missing out. Really interesting design. The front and rear suspensions have no real pivots. The plastic is used as a flex hinge. The super narrow front tires give it a really unique look. They are an iconic buggy for sure. Very nice work on the restoration!
Factory Works website
- Has thanked: 2287 times
- Been thanked: 1994 times
A very nice restoration , I love all the frame type body cars .
Wow those look exactly like promo pics from back in the day! Very nice!!!!
- Been thanked: 288 times
Looks good and runs good, too! I remember selling quite a few of these back in the day when I worked at a hobby store.
- blast
- Has thanked: 99 times
- Been thanked: 44 times
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
I still have my Cox Bandido, yet another variation of this chassis. Even though they are from the mid 80's, I picked mine up on clearance in the early 90's.
I chose to keep the msc in mine as I don't really have much intention on running it. It also still has the original (slightly worn) tires. It currently still has the original body, paint, and decals (poorly executed by a 14 year old), but I'm thinking that a new TBG body and MCI decals might be in order.
- 21 Replies
- 1694 Views
Last post by besty22
- 2320 Views
Last post by gpster
- 1455 Views
Last post by juicedcoupe
- 2782 Views
Last post by amsa116
- 622 Views
Last post by Rattlesnaker
- 981 Views
Last post by opelgt21
- 1597 Views
Last post by THEYTOOKMYTHUMB
- 521 Views
Last post by SMOKE-DOG
Users browsing this forum: Ahrefs [Bot] and 16 guests
