Ultima Pro XL wheelbase?
- XLR8
- Has thanked: 1238 times
- Been thanked: 890 times
I've been searching the forums and someone mentioned that the XL wheelbase is ~1/2" (13mm) longer than the base model. But the body I have from Penguin has two cut lines and they're probably only about 6mm apart. Does anyone know for certain how much longer the wheelbase is for the XL cars?
If someone has an sample of both chassis and could take a measurement from each that would be awesome.
thanks.
thanks.
- tintin74
- Been thanked: 23 times
Re: Ultima Pro XL wheelbase?
Hey Buddy,
Just measured a Ultima MK1 vs an XL, and I can confirm the XL is 13 mm longer.
260mm MK1 vs 273mm XL.
Cheers!
Cheers!
Check out http://www.kyosho-optima.com and my Facebook Group https://www.facebook.com/groups/optimaseries/
- XLR8
Thanks so much for providing those measurements.
By the way, does anyone know what these two holes are for? I've had a look at a variety of Ultima buggy manuals and all chassis plates have them but they don't appear to serve any purpose. I can't see anything mounted using these two holes.
Maybe they're meant to function like scuppers to prevent dirt accumulating between the suspension arm and the trans??
- Has thanked: 822 times
- Been thanked: 2418 times
They line up with the set screws in the outdrives
Factory Works website
- XLR8
Yes, I guess they do align.
...and the right outdrive set screw would be very hard to access without the hole.
The manuals for the Ultima and Turbo Ultima don't show the holes but manuals for subsequent models do - even those that use a ball diff which don't require set screws.
I have a few old chassis plates and all of them have holes.
thanks Jeff!
thanks Jeff!
- Has thanked: 7 times
- Been thanked: 41 times
After having my Pro XL since the mid-90's, I was today days old when I learned of this black magic...
- 835 Views
Last post by tiger1
- 696 Views
Last post by Mr. ED
- 1805 Views
Last post by Synergy
- 21 Replies
- 4439 Views
Last post by sundevil67
- 1870 Views
Last post by Delorean
- 66 Replies
- 9347 Views
- 832 Views
Last post by keithrc
- 686 Views
Last post by GJW
Users browsing this forum: No registered users and 15 guests
